Vacuum Issues
Old Apr 23, 2011 | 10:15 PM
wesbrand's Avatar
wesbrand
Vacuum Issues
Hi, i am new to this site and to my 1987 F150. It is a I6 300 4.9L. I am trying to find a vacuum diagram for the truck. the factory sticker is torn right down the middle of the diagram. The issue i'm having is it's failing emmissions for high hydrocarbons. it's idling really rough and sometime stalls out while at idle. When you remove the vacuum line from the intake manifold that goes to the fuel pressure regulator valve it idles up and does ok. as soon as you reconnect it, back to rough. i have replaced the fuel pressure reg. valve, the PCV valve and hose to air box, the EGR and it has a new fuel pump. have added fuel injector cleaner and have cleaned the IAC and throttle body. no luck. it's almost like it's not getting enough air at idle and when you remove the vacuum hose from the top of the intake manifold it gets enough to run right?? any ideas?
Old Apr 23, 2011 | 10:53 PM
big-ugly's Avatar
big-ugly
Well I can't help you with the diagram, but welcome to FTE! These 4.9l's have a tendancy to develope vacuum leaks. Hopefully someone else will chime in and give you some advice.
Old Apr 24, 2011 | 07:08 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...am-needed.html Click on this link and follow the instructions by rla to get a vacuum diagram.
Old Apr 24, 2011 | 08:13 PM
wesbrand's Avatar
wesbrand
thanks
thanks for the welcome and the help everyone. i actually saw that thread the other day and checked out that website but it only goes as early as 1988. thanks for the info again everyone.
Old Apr 24, 2011 | 10:34 PM
rla2005's Avatar
rla2005
The diagram for a 1988 should be close to your 1987. If you go one year back, 1986, it looks like this:
Old Apr 25, 2011 | 07:36 PM
wesbrand's Avatar
wesbrand
awsome...thanks for the help!
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
sittinlow88
16
Jan 3, 2015 06:24 PM
ewalt98
Sep 6, 2014 05:33 PM
HEpTJJ
Sep 11, 2013 10:58 PM
rex7enguy
1997 - 2003 F150
May 3, 2012 12:51 AM
