'97 Explorer transmission question
Old Apr 23, 2011 | 02:35 PM
lectricman's Avatar
lectricman
Question '97 Explorer transmission question
I just bought a '97 Explorer with the 4.0 OHV and what I'm assuming is the 5R55E tranny. The tachometer reads just under 3,000 rpms at 60 mph in overdrive. The truck has 3.73 gears according to the tag on the rear axle. (I also manually turned the rear tires and counted the driveshaft revolutions to verify). Is the transmission not shifting into overdrive or could it be slipping enough to elevate the rpms? It is also a little sluggish to make the final shift sometimes. I've read about some of the problems with this tranny, but still don't know exactly where to start. I have already changed the fluid and filter and added Lucas transmission additive. Thanks for the help!
Old Apr 23, 2011 | 09:31 PM
aquanaut20's Avatar
aquanaut20
I have the same configuration with ControlTrac. At 100km (60mph), I am steady @ 2100RPM...
BuckHammer
18
Aug 17, 2024 10:39 AM
Dillon Rogerson
Feb 8, 2016 03:51 PM
Josh726
1997 - 2003 F150
13
Dec 4, 2015 08:56 PM
baxter17
1983 - 2012 Ranger & B-Series
Apr 29, 2010 09:44 AM
TOMKLU
Apr 14, 2004 01:52 PM
