Automatic column part # help
Old Apr 23, 2011 | 11:23 AM
mbrowne's Avatar
mbrowne
Restoring my 58 auto column but need to find some parts that are hard to find. I need the plastic bushing at the bottom of the column shift shaft, the shift indicator, and pointer. If someone has the part numbers I can search the net. Or if someone has some old stock I can check with. Thank, Mike.
Old Apr 23, 2011 | 11:59 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
mbrowne, NumberDummy will eventually be along and can provide those numbers.You should know,however, that an automatic in the 57-60 years is fairly rare,and parts for an automatic column might be hard to source.Keep checking back,Bill will see this thread sooner or later.
