Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Setting my carb.
Old Apr 23, 2011 | 10:35 AM
etnies13's Avatar
etnies13
Setting my carb.
I need some advice,the carb on my 40o (I believe its a motorcraft 2 bbl) needs some adjustments the truck is notrunning too well. When it warms up and i gun it the motor bogs out then starts to go. I know where the gas/fuel mix is and the idle speed and there is one other adjustment screw that i am not sure about underneath the front of the carb. Anyonehave any ideas on a good starting point for these setting so i can get it running well enough to take it over to draggins today hopefully. lol
Old Apr 23, 2011 | 04:17 PM
Fomoko1's Avatar
Fomoko1
Unless someone here jumps in soon re post this in the FTE ''Fuel Injection, Carburetion & Fuel System'', click on this link Fuel Injection, Carburetion & Fuel System - Ford Truck Enthusiasts Forums
I usually just buy a rebuilt 2 bbl carb from Swift Filtration in Saskatoon/651-3289, for about $160 I get a sweet ready to use carb.
Old Apr 23, 2011 | 04:43 PM
preppypyro's Avatar
preppypyro
First step is first, if it aint clean, clean it.
After that what i usually do is find the stock settings out (from google or a forum) set it to that, then adjust with 1/4 turns.
I havent ran into a carb that I have worked on yet that I couldnt figure out, just takes a little patience and tinkering.
Old Apr 24, 2011 | 11:56 PM
Snowking's Avatar
Snowking
Believe it or not with Motocrap carbs my best luck has always been to take off the automaticchoke and put on a mechanical system. My old 1975 360 did that for years. Finally swapped out choke and it smartened up.
jdon88
Jan 20, 2016 09:45 AM
Locorotc
16
Dec 5, 2011 10:34 AM
cowboywanabe
Dec 15, 2007 10:01 PM
Brian77Ford
Apr 23, 2004 01:08 AM
serving_time
Oct 24, 2003 03:25 AM
