u-joint question
Old Apr 21, 2011 | 09:39 PM
JD_F250's Avatar
JD_F250
u-joint question
Hey guys quick question. 2005 f250 front axle shaft u-joint. the stock ones have clips on the inside and the ones i got new, have outside clips. did i get the wrong ones or will they work?
Old Apr 21, 2011 | 11:45 PM
steelhead2's Avatar
steelhead2
Unless the shaft yokes are machined to accept internal outboard clips I would say they are the wrong ones.usually if a u joint has inner clips the shafts will be smooth.
