Weathertech vrs. Huskey floormats?
I have had both Husky Floor Liners (not the Heavy Duty Floormats) and WeatherTech's DigitalFit FloorLiners.
The Husky liners did their job quite well. They are formed to contain the water, mud, and other debris with their deep lips. My only complaint was actually that the Husky Floor Liners were almost too thick, and that made them a bit of a pain to pull out & clean.
The WeatherTech liners have also done their job quite well. The front liners are built to channel water to the door opening. My main complaint with this is that it has caused some problems with water refreezing in/on the weather seal at the bottom of the door(s). Secondly, their rear floor mat (for a Crew Cab) has a tendency to wander around a bit. (Husky's rear liner stayed in place much better.)
Honestly, both are worth their money, and having had both, I would be hard pressed to say which I like better. What I will add is that the Husky offers a center hump protector spans that carpeted gap between the driver & passenger floor liners. So that may tip your decision in favor of Husky....especially if it is a work truck, or used a lot for camping, fishing, hunting, etc.
I've had the WeatherTech Floorliners front and back in my '07 SCrew since new, and I would buy them again for my other vehicles if they made them for older cars and trucks. My carpets still look like new under the liners and I never end up with water puddling up on the floors because it drains right out. Never had an issue with the water freezing up the bottom door gasket (but the top door gaskets freeze all the time if I don't spray silicon on them every couple of weeks).
I've got Weathertech in my '10 XLT Screw. I have had Weather tech in my last 4 Ford vehicles and love them. Huskey's may be ok but I've been more than satisfied with Weathertech. I had an issue with one of the new Weathertech mats when I first got it and Weathertech sent me a replacement without having to return anything. I had the replacement in 2 days.
I would guess that the Husky's are well worth the $50 savings. I almost bought a set of them for my '10 XLT just to check out the differences.
my parents have the husky liners on there vinyl floor and they find that they slide around a fair bit. they have the little spikes on the back side and stick up on the vinyl. but i do like the fact that the husky's don't funnel the water to the rocker panel and rot the harness or truck out. For the $50 in savings i would get the husky's. they are both excellent though. It also looks like husky has changed them from when i had them in my 06
on
Both mats ship from the exact same address say the accessory guys...sounds like weather tech might be the top brand, and husky the 2nd tier.
I have WT digital fits in my truck, best mats I've owned. They even provided a spot to cutout for the amp in the back ( visible in shortride's second photo, against the passenger door....lousy place for an amp for a guy that uses the floor, oh well).
