HELP dash removal
Old Mar 20, 2003 | 11:58 AM
crustydoughboy's Avatar
crustydoughboy
Question HELP dash removal
Hi gang. i gotta problem, i want to put the prodigy brake controller in the little opening (made to store cd's) next to the pull-out cupholderashtray. Does anyone know how to remove that portion of the dash? I see 2 screws behind the cupholder and 3 below it and 2 along the bottom edge of the dash. Icould sure use some imput.
thanks
GOD BLESS THE BOYS AND WOMEN FIGHTING FOR OUR FREEDOM
Old Mar 21, 2003 | 07:35 PM
tkj99's Avatar
tkj99
Talking HELP dash removal
Hi Crusty. Like you, I wired up the harness to the brake controller, and then couldn't find the plug. I looked for similar posts in the heavy duty truck section, and found the answer there. You do not need to take that dash cover off. Just remove the fuse panel cover under the steering column. The plug is to the right of the steering column, and is attached to the other side of the metal frame supporting the dash. Its hard to see, but its there. I used a small mirror and flashlight to help find it. The male connectors are facing downward. The wires going to the plug are larger and more colorful than the other ones under there, and come from the passenger side of the X. Hope that helps!
