p0455
Old Apr 20, 2011 | 06:44 PM
billdarrah's Avatar
billdarrah
p0455
I have this code coming up on my 99 flex fuel ford ranger 3.0L. It says that it is an emissions high leak. how do i fix this?
Old Apr 20, 2011 | 07:14 PM
powersmoked's Avatar
powersmoked
P0455=gas cap code
Old Apr 20, 2011 | 09:16 PM
FireMe's Avatar
FireMe
P0455 means there is a large leak in the evaporative emissions system. This means all of the fuel vent lines and related components like the filler neck, gas cap, canister vent solenoid, vapor management valve, etc.
You can try inspecting all of the components for obvious failure but other than that you will just be guessing. You need to take it to a shop to have the system smoke tested to find the leak.
Old Apr 21, 2011 | 05:14 AM
powersmoked
remove and replace the cap then clear codes, if that does not work->inspect all components the fillet neck and hose do go bad on these trucks. at this point you might want to get a new cap for $15 does the cap click when you turn it? rockauto sells the caps and this place sells the filler neck Ford Ranger Fuel Tank Filler Neck at AM Autoparts
also I do a search and you will find this problem discussed alot. here is one thread I found Cracked Fuel filler neck and P0455 - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
12gaugeCharlee
New Member Introductions
Jan 24, 2018 10:05 PM
Lawrence Taylor
Engine Swaps
Aug 5, 2017 09:33 AM
Havecooker
Apr 9, 2017 11:07 AM
Jaime74656
Dec 25, 2015 08:53 AM
DeGideo
1978 - 1996 Big Bronco
Mar 25, 2002 11:09 AM
