I think I may need help
Old Apr 19, 2011 | 09:08 PM
billabongboy's Avatar
billabongboy
Evening FTE!
So I have developed a problem with my pickup that has rendered is useless and I'm thinking it is done for but I would like some of your expertise. I will try to explain it to the best of my knowledge but I am the least thing from a diesel mechanic. I was driving back from fishing the other day when I noticed my truck was acting real funny as in shifting weird and slipping real bad, so i figured the transm was on the fritz so I decided to change my Trans fluid and filter today to see if that was the problem. Ran it through all the gears while sitting still to get the fluid circulating ( not sure that is the correct way to do it) and then took it for a test drive up the road and back. While I was driving up the road I heard a real loud grind sound then the whole truck jerked forward and the boost gauge was reading "zero" and you could hear that the turbo wasn't working. At that point I got real worried so I limped back to my house to try and diagnose the problem to see if it was just a intercooler boot that blew.... it wasn't, all 6 looked perfectally fine. So I'm stuck at a stand stilling thinking that my truck is DOA now and I am really worried that that is the correct assumption. Any help would be greatly appreciated.
By the way the truck is a 2001 F250 Auto trans.
Christian
Old Apr 19, 2011 | 09:12 PM
tritonman2001's Avatar
tritonman2001
Pull the air intake off and check the wheel to see if it is still in one piece, and how much play is there. You may be in for a turbo rebuild, or possibly a new one.
Old Apr 19, 2011 | 09:14 PM
billabongboy
I had that off while I was checking the boots and it seemed that there wasn't any play and it spun without a problem.
Old Apr 19, 2011 | 09:23 PM
clintbonnie's Avatar
clintbonnie
Maybe your mechanical diode in the trans is bad... I am no expert, but have read a lot of posts about the 2001 diode problems here on the forum.. I believe it affects trucks built between 7/2000 and 3/2001..
Old Apr 20, 2011 | 07:44 AM
riverrat41's Avatar
riverrat41
Bump for more folks to see and maybe a member lives near you that can help diagnose further and we can be of more help.These internet diagnostics/fixes are tough sometimes.
Old Apr 20, 2011 | 08:08 AM
billabongboy
I appreciate it. I'm severely overwhelmed with this problem. When it comes to the F250 gas I know what I'm doing but since that one got totaled and I got this 7.3 I'm over my head with the whole diesel thing.
Old Apr 20, 2011 | 08:18 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Can you still start the engine and it idles ok? What does it do if you put it in gear now?
Old Apr 20, 2011 | 08:21 AM
billabongboy
Engine starts up just fine like it doesn't have a care in the world and I can put it into gear. Its shifting a little funny still and when I get to about 40 mph its like it pulls forward alot then something has a grinding sound and it jumps down a gear. I'm sure this has been asked but how much oil goes into those I just filled it up to the "Fill line" on the dipstick but it only took 12 quarts.. is that right?
Old Apr 20, 2011 | 08:23 AM
white Buffalo's Avatar
white Buffalo
Any Check engine light? Do you have a scanner to check for trouble codes?
Old Apr 20, 2011 | 08:26 AM
miller_feed
Sounds like your trans is craped out. I hope you checked the fluid with the engine running.
Old Apr 20, 2011 | 08:31 AM
billabongboy
The only code it threw was the intake sensor thing because i put the boost gauge in.
And yes i checked it with the motor running.. I was kind of hoping it was something stupid instead of the whole transmission going bad. Now i have to try and find someone to buy the thing so I can go back to a old f250 i found for pretty cheap
Old Apr 20, 2011 | 08:41 AM
white Buffalo
plug your predator programmer in and go to the transmission menu and read the live data tables. If you think it is still driveable see if your torque converter is locking up at @ 35 mph. Also check in the same table if the rpm's match what you see on the dash.
Old Apr 20, 2011 | 08:46 AM
Brother Les's Avatar
Brother Les
[quote=billabongboy;10242662]Engine starts up just fine like it doesn't have a care in the world and I can put it into gear. Its shifting a little funny still and when I get to about 40 mph its like it pulls forward alot then something has a grinding sound and it jumps down a gear. I'm sure this has been asked but how much oil goes into those I just filled it up to the "Fill line" on the dipstick but it only took 12 quarts.. is that right?[/quote]
When I drained mine it took
18qts, so you are a little low.
Old Apr 20, 2011 | 08:53 AM
billabongboy
In anyones personal or professional opinion should it be acting like that with 6 quarts low? Also the oil that came out was no where near 18 quarts it was only about 10.
Old Apr 20, 2011 | 09:01 AM
DieselCamper01's Avatar
DieselCamper01
[quote=Brother Les;10242753]
It may depend on the method he used to drain the fluid also. If he didn't drain the converter that is some (not sure how many quarts it holds though).
