EBPV leak question
Old Apr 19, 2011 | 11:12 AM
rtazz17's Avatar
rtazz17
EBPV leak question
I posted a couple days ago but will give background again.I found small drip of oil on garage floor.Looked under truck and it had oil drip hanging off the drip cover,not soaked by any means.Traced it back to ebpv.The rod is covered in oil and black.Dont believe its the pedistal leaking...(but those will get replaced as well)Valley dry except at very back where it looks alittle wet,not a puddle by any stretch.Hpop bone dry.Truck has 95000 on clock.So another member here suggested unplugging the solenoid so it doesnt activate.Mine still activates because of cold temps still, up here in northeast.I did unplug it but havent done much driving yet...Will this stop any leaking as well if its unplugged and not activating?Or will it still leak and just blow out all over?I am in process of getting a parts list and will order and delete the rod..But wanted to know how much time you guys think I have b4 she blows.....Or if it will blow.I would like to wait for warm weather to do the job...Thanks
Old Apr 19, 2011 | 11:35 AM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
When you unplug the solenoid it will not activate so no oil is going to get to the chamber where the piston is, to move the rod, so you should be good to go.
Old Apr 19, 2011 | 11:45 AM
joeyd61's Avatar
joeyd61
I am not so sure.. mine leaked unhooked..usally the leak is due to o-ring failure once the o-ring fails it will usally leak anyway...just my .02
Old Apr 19, 2011 | 11:50 AM
rtazz17's Avatar
rtazz17
I was thinking on a non ebpv pedistal or should I tap and fill the hole?I just dont want the pedistal to leak after its all together again....If I do that How do I get rid of the flap or whatever its called on the turbo?freeze plug?Anyone have a link to a non ebpv pedistal install?Im searching now for one...By the way Ive never removed my turbo and have to admit not looking forward to it.Its my daily driver and dont have a week to do the job..Hope this goes well when I start it...
Old Apr 19, 2011 | 11:56 AM
joeyd61's Avatar
joeyd61
With mine I just gutted the epvb threaded the hole and locktited a plug in it..as far as the flap goes I used the Banks Power Elbow..sorry i dont have a link to the "how to" but its not complicated, you will want to replace the pedistal and turbo o-rings
Old Apr 19, 2011 | 12:37 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Here's a couple how to's.
https://www.ford-trucks.com/forums/8...d-my-ebpv.html
Gutting the Exhaust Back Pressure Valve - 1994-1997 Power Stroke FAQ
Old Apr 19, 2011 | 01:46 PM
rtazz17's Avatar
rtazz17
Thanks all....Seems alot cheaper to keep the old pedistal..IF I decide to just keep the old pedistal and delete the valve,when I put the valve cover back on is there an oring that I should change before I put the snap ring back on?also any advice on removing the uppipes from the back of turbo?aside from the plugs I need to fill where the old shaft goes and where the old flapper was,and pedistal orings are there any other parts I need?new screw or bolts for turbo?
Old Apr 19, 2011 | 03:10 PM
rtazz17's Avatar
rtazz17
anyone know the turbo mounting bolt head size so I dont strip them?Whats recommended to get the back one off?6 inch extention socket?stupid question but I could see myself stripping the bolt,just my luck...
Old Apr 20, 2011 | 08:53 AM
Larry_the_handyman's Avatar
Larry_the_handyman
The turbo mounting bolts are 13mm, pedestal bolts are 10mm and the v-bands are 7/16.
Old Apr 20, 2011 | 10:59 AM
rtazz17's Avatar
rtazz17
Thanks... Im going through my list of parts to order..I read somewhere about a turbo gasket reinstall kit being needed? Is this true and if so where does this gasket go?
Old Apr 20, 2011 | 11:05 AM
mtdigger's Avatar
mtdigger
Dieselorings.com, bob will hook you up, get the re-install kit, all nicely packaged together.
Old Apr 20, 2011 | 11:09 AM
rtazz17's Avatar
rtazz17
Im deleting it altogether so is this kit needed.. Alittle confused..
Old Apr 20, 2011 | 11:15 AM
mtdigger's Avatar
mtdigger
Oops, no I don't think so...I got it with my compressor wheel, but I don't think you'll need it
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Give Bob at Diesel O-rings a call he will be more than happy to help you out with what you need. Just tell him what you are doing. Go to his web sight and get his contact number www.dieselorings.com
lshort
Jul 2, 2017 09:06 AM
unleashd
Dec 10, 2016 03:51 PM
AKHunter93
28
Nov 27, 2016 01:01 PM
dlburch
2004 - 2008 F150
13
Oct 19, 2016 05:10 PM
Karruda
Nov 16, 2015 10:39 PM
