84 2.8L conversion
Old Mar 19, 2003 | 11:41 PM
Wild_Buffalo's Avatar
Wild_Buffalo
Question 84 2.8L conversion
Morning All,
Posted about a month ago on the problems I was having with my 2.8L Engine. I decided to convert it to an earlier Carb and Distributor Gear to solve the low MPG and Idle problems. Just was wondering if you all knew if I need a different ignition module to work with the distributor. It is not a problem to find one but just want to know if it needs to be converted as well.
Just to let you know I found a Carb and Dist off of a 77 Mustang 2 for the replacement parts.
Thanks for the Help,
KEN
AKA Wild Buffalo
Old Mar 20, 2003 | 12:12 PM
mickelsons's Avatar
mickelsons
84 2.8L conversion
I believe that we used a module off of a '79 mustang, but am not positive, we did have to cut one of the plugs and wire it to the other because the plug types were slightly differant.
Old Mar 20, 2003 | 03:44 PM
amp17757's Avatar
amp17757
84 2.8L conversion
Although these modules are all nearly identical, they aren't DEAD NUTS identical. If you buy one, just tell the salesperson that it's for a '77 Mustang, since that essentially what you have now. Then, ask if the part numbers for the model year & engine of your Ranger are identical.
