Clutch engagement problems
Old Apr 17, 2011 | 10:42 PM
theFORDGE's Avatar
theFORDGE
Hey I got a problem. My clutch travels all the way To the floor before it engages. I can still drive but it is particularly hard to start. I have heard that there is a little clip on the clutch linkage that goes through the firewall that cleans up the slack. Just wondering what this clip is or if need to fix something else.
Stu
Old Apr 17, 2011 | 10:50 PM
theFORDGE's Avatar
theFORDGE
92 f350. Zf5 tranny
Old Apr 18, 2011 | 10:34 AM
Lazy K's Avatar
Lazy K
Hydraulic Clutch Troubleshooting .: Articles Click on this link and read it.
Yours should be OK but also check the firewall for flexing where the master cyl bolts on.
Could also be a bad master cyl.
Could also be air in the system.
What engine do you have?
Do you have any fluid leaks?
Old Apr 18, 2011 | 11:36 AM
theFORDGE's Avatar
theFORDGE
Haven't noticed any leaks. I am going to try and change out the bushings today. Hopefully that works
Old Apr 18, 2011 | 02:25 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...f-5-speed.html Also read the post by PLC7.3 in this link. Some good info on the clutch linkage.
