f250 towing capacity
Old 04-17-2011, 02:30 PM
Robertcoupe's Avatar
Robertcoupe
Robertcoupe is offline
Question f250 towing capacity
I now own a 1973 f250 4x4 with a 390ci.
I am looking at getting a trailer, and was wondering if anyone knows what the towing capacity of these old trucks are.
I know they are super heavy, so the capacity may be less
but the old trucks are noticeably more stout, so the capacity may be more.
im sure what ford says, differs some from what people have done.
does anyone have numbers?
Old 04-17-2011, 05:06 PM
AntiHero55's Avatar
AntiHero55
AntiHero55 is offline
well when my grandpa owned my 78 f250 supercab 4x4 with a 400 he used to pull tractor trailers/semis at this trucking company he worked at. my dad now works at that company and everytime i go down there the old-timers tell me about all the things he used to pull with that truck. one told me he once pulled a fully loaded dump truck up a pretty decent sized hill they have there.
the truck is a 78 f250 with a 400 in it paired with a c6 and np203. truck also had 4.10s in it.
Old 04-17-2011, 08:36 PM
Rico47635's Avatar
Rico47635
Rico47635 is offline
If you happen to have the manual, it should give you those specs. If not, the sticker on the door frame may give you the GCVW rating. The GCVW rating is the weight of the truck and trailer combined. Find out what your truck weighs and substract that figure from the GCVW figure. Just remember that towing isn't just about how much you can pull. Pulling something is the easy part. It's the stopping that can get tricky.
Old 04-17-2011, 08:53 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
^^Very good point. From my experience, I've run out of brakes before I've run out of power or maxed the springs and axle out. Back when I was running the 360 I'd pull 7-8k lbs around regularly. A little harder to stop but no problems. Now it's 10k with trailer brakes.
Also I don't think the GCVWR is on the door tag. I think it only lists the GVWR. Hopefully someone has got a manual or something and can set us straight with the factory ratings for the 3 different GVW ratings available to the F250 4x4.
2015F350
2017+ Super Duty
23
04-18-2019 09:36 PM
automaticlee
10-05-2016 07:38 PM
alexmartin33
1999 to 2016 Super Duty
30
02-21-2016 07:39 AM
ohmar99
33
12-28-2012 08:58 PM
fordman400
05-06-2010 08:40 AM
Quick Reply: f250 towing capacity
