Sponsored by: Real Truck
coolant hoses rubbing
Old Apr 16, 2011 | 09:19 PM
VTX1800rider's Avatar
VTX1800rider
I replaced my steering damper tonight. While underneath and after the install I noticed the two lines that go over the cross member were laying on the cross member. I had a flash back about my old expy did the same thing and had worn out a spot on the hose to a point could have blown anytime. So I pushed up the lines and they had a wear spot where they touch the cross member too. I have some 1/4 thick rubber material. I took some and made a small wrap with some zip ties around the hoses like a sleeve. I slid it down to would protect the hoses from rubbing. Not ground breaking info but gave me a piece of mind.
Old Apr 17, 2011 | 09:44 AM
adam10's Avatar
adam10
i noticd that on my 99. i took pvc and split it and zip tied it fast to avoid further wear.the pvc was what i had laying around.
