Wiper problems
Old Apr 16, 2011 | 10:13 AM
88dually's Avatar
88dually
Wiper problems
88 350 dually, wipers run real slow, like 1/4 speed and 1/2 speed on high, is it the motor or switch ?
Old Apr 17, 2011 | 08:30 AM
Gomer1's Avatar
Gomer1
Mine was doing the same thing...it was the motor
Old Apr 17, 2011 | 09:00 AM
88dually's Avatar
88dually
It unbolts from under the dash, right ? What a pain in the ball sack job
Old Apr 17, 2011 | 11:07 AM
SideWinder4.9l's Avatar
SideWinder4.9l
you have to pull the cowl (6-7 screws), and unbolt the wiper motor (3 bolts IIRC), and undo the wiper arm linkage (1-2 bolts, and PITA)....
Have fun
-Wes
Old Apr 17, 2011 | 11:46 AM
88dually's Avatar
88dually
Does the cowl unbolt from under dash ?
Old Apr 17, 2011 | 11:54 AM
SideWinder4.9l
How are you getting that you have to go through the dash?
No, the cowl un bolts from under the hood....When you raise the hood, you will see little black screws going around it....And IIRC, theres 2 more on the top. between the wipers, recessed in....
-Wes
Old Apr 17, 2011 | 12:03 PM
88dually's Avatar
88dually
ok,the ones holding the rubber
TY
