Hitch
Old Apr 16, 2011 | 08:32 AM
Rogue427's Avatar
Rogue427
Hitch
Looking for a hitch for my 69 on a 72 F250 4x4 frame.
The higher the rating the better.
Any recomendations. Thanks.
Old Apr 16, 2011 | 08:13 PM
akforceten's Avatar
akforceten
I used one from a dodge truck 94 95 96 . The only thing I had to do was cut it down to fit the frame an re-weld it. It works great!
Old Apr 17, 2011 | 10:22 PM
crazed87bronco's Avatar
crazed87bronco
I'll be using one off a 94 explorer it was mounted on the rear frame rail ill be using it as my front frame crossmember ill need to cut it down to fit but it will be nice to have a receiver on the front
Old Apr 22, 2011 | 01:30 AM
Bumpside Man's Avatar
Bumpside Man
I'm looking for one to fit my 70 F-250. Hitch shop had a Class III (Acme I think) they said would work, but I really wanted at least a Class IV receiver. LMC Truck has one rated a Class III too. Tractor Supply has a Class IV Multi Fit by Reese that I am thinking about modifying to work. It is rated at 7000 lb max trailer weight carrying, and 12,000 lb with a weight distributing hitch. You will have to make two 1 inch thick spacers to use this unit though. Going to try to find some info on Reeses Titan Hitches, they have a 2.5 inch receiver box, and are rated a Class V with 12,000 lb weight carrying and 14,000 lb distributing.
I'm also in the process of measuring my truck for a B&W turnover hidden gooseneck ball hitch the trailer shop thinks will work.
Old Apr 22, 2011 | 07:26 AM
Rogue427's Avatar
Rogue427
Frame is 34"
Going to call on one that might fit. A class V one.
Will let you know what I find out.
Old Apr 22, 2011 | 07:50 AM
77 Bronco's Avatar
77 Bronco
I have a Class III/IV on my truck that is a direct bolt on. I'll get the part # and manufacturer soon for ya. It's a Reese or Drawtite I think. I'll get back to ya.
Old Apr 22, 2011 | 07:51 AM
77 Bronco's Avatar
77 Bronco
P.S. it's on my f-100 lwb
Brad sxt
Nov 24, 2015 08:33 PM
monarchff
1997 - 2003 F150
May 12, 2008 10:02 PM
lee
Sep 26, 2004 11:52 AM
maydaymike
Apr 13, 2003 05:12 PM
luxury 4x4
All Things Towing
Jun 3, 2001 11:57 AM
