Header questions...
Old Apr 15, 2011 | 09:58 AM
KrautBurner's Avatar
KrautBurner
Question Header questions...
I've got a 1977 F250 SuperCab 2wd 460 4bbl C6
I am considering going with a set of headers.
who makes decent headers for these trucks?
I'd prefer something that isn't gonna leak
I am under the impression that Long Tubes will give the most HP gains (mostly in upper RPM ranges)
and Shorty headers will give more Low End Torque
is this the case for my 460ci V8?
which makes me lean towards some Shorty or Mid Length headers
I already have True Dual 2.25 or 2.5" exhaust (with some 36" glasspacks)
my experience is only with late model Fuel Injected GM LSx engines
I've got a set of Staneless 1-7/8" Pri / 3" collector Kooks LongTubes on my 11 Second GTO
Old Apr 15, 2011 | 10:47 AM
MikePacey's Avatar
MikePacey
For you situation long tubes are going to be cheaper, more efficant, and better results BUT you also need to run the correct diameter pipe and the long your exhaust is the more low end torque you'll have. You go to the races you ever seen the guys who run header extentions? its to increase the torque. Now if your 460 is stock then I would run a set of long tubes with 2 1/4 pipes and either exit in front of the rear wheels or all the way out the back.
Old Apr 15, 2011 | 10:48 AM
MikePacey's Avatar
MikePacey
BTW got any exhaust vids or race vids of that goat?
Old Apr 15, 2011 | 10:58 AM
montana_highboy's Avatar
montana_highboy
Look into a set of L&L headers.
Old Apr 15, 2011 | 11:00 AM
KrautBurner
I know there's some crappy vids out there if you search KrautBurner GTO
here's my old PhotoBucket gto at bremerton raceway pictures by krautburner - Photobucket
Krautburners first ever 11 sec pass w/ gto and 100 - Car Videos on StreetFire#
http://www.streetfire.net/video/krau...t-p_116765.htm
Dyn vid: My car is at 4:16
this was a weak run
http://www.youtube.com/watch?v=viq6TasaRzo
I'm the guy in the hatch of Ryan's Camaro at 5:16 (we had 4 people (over 200lbs each) in the car, it kept spinning the drag radials on the rollers)
Old Apr 15, 2011 | 11:26 AM
704 dentside man's Avatar
704 dentside man
If it were me...I'd look at a set of Thorley Tri-Y's first, then Mad Dog, then L&L.
KrautBurner
Thanks
L&L Products
are these the right ones: $549 for nickle plated / $489 for black
L&L Products
1967-79 F100/F150/F250/F350 2WD Ford Trucks Complete With Hi Performance Header Gaskets, Collector Reducers and Installation Hardware.
Old Apr 15, 2011 | 12:06 PM
montana_highboy
That would be them
