Numberdummy help
Old Apr 14, 2011 | 09:59 PM
frty7ford's Avatar
frty7ford
Numberdummy help
I am looking for some part numbers and locations for my t85 I need the sungear with snap rings
planetary with 4 pinions
freewheel
gasket & seal set
thanks
Old Apr 15, 2011 | 04:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by frty7ford
I am looking for some part numbers and locations for my T85.
I need the sungear with snap rings, planetary with 4 pinions, freewheel, gasket & seal set.
I assume this T-85 O/D trans is from a 1965/71 F100 or 1965/67 Galaxie/LTD. If not, some of these part numbers will be in-correct.
B7A-6927-A .. Oil Seal-Governor to Housing (Warner: 4804-C).
B3TZ-7A034-B (replaced B3TZ-7A034-A) .. Output Shaft Bushing.
C5TZ-7052-B .. Output Shaft Seal (Warner: 3-110A).
B7SZ-7B331-A .. Small Parts Kit (washers/shims).
8L-7654-A .. Snap Ring-Overdrive Ring Gear (Warner: R6-93) Zero / Note: 16H-7654-A has the same specs, I found some of these.
B7A-7661-A .. Gasket-Overdrive Housing to Adapter (Warner: R11-146C).
16H-7666-A .. Snap Ring-Overdrive Balk Ring & Gear to Adapter (Warner: R10-11).
8L-7670 .. Overdrive Sun Gear (Warner: AR11-4).
8L-7672 .. Snap Ring-Overdrive Free Wheel Unit to Main Shaft (Warner: R1-9).
C5AZ-7673-A (replaced 8L-7673) .. Overdrive Planetary Gear Assy (Warner: AR11-30C) Zero.
C5AZ-7675-A (replaced 8L-7675) .. Overdrive Free Wheel Unit-includes Rollers (Warner: AR11-46A) Zero.
26H-7693 .. Oil Seal-Overdrive Solenoid at Adapter (Warner: R7C-18).
The parts marked zero I could not find. The rest of the parts I found, but myriad sources have them.
I'm not typing these myriad sources, as I've already spent two hours looking these parts up...then searching for them. It would take me another hour (at least) to list the sources.
Click on my user name, pass along your phone number and best time to call in a P/M or email (I'm in SoCal). I'll call you, give you the sources/phone numbers.
The Warner part numbers are what autoparts stores go by, but how many of these parts...autoparts stores can obtain, I dunno.
The B3TZ-7A034-B bushing is available from Ford, the rest of the parts are obsolete.
Myfreeford
54
Feb 15, 2019 04:33 PM
Truckin23
Oct 6, 2014 08:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
