C6 no auto shift
Old Apr 14, 2011 | 09:16 PM
Jason6969's Avatar
Jason6969
C6 no auto shift
C6 just rebuilt, Transgo C6 spring kit, forward and reverse normal, won't shift 1-2 in drive or 2-3 will shift manually but no high gear. governor? valve body? it did have you drill the separator plate and drill through a partition in the valve body " lube upgrades"
Old Apr 29, 2011 | 07:37 PM
Chiefrider007's Avatar
Chiefrider007
Sounds to me like either you don't have vacuum to the modulator or the kick down is stuck. Also check your screen on the top of the valve body and filter if you pull the pan back off to see if you have anything in them.
