p0700
Old Apr 14, 2011 | 08:44 PM
slipkorn34's Avatar
slipkorn34
p0700
ive got a 99 superduty 2wd and i scanned for codes and came up with p0700 which is transmission control system malfunction, my tranny is a zf547m
just wondering if anyone has anyideas as im still not used to this drivetrain yet.
Old Apr 14, 2011 | 11:13 PM
slipkorn34's Avatar
slipkorn34
iirc the tcm on these trucks is part of the pcm right? so i just need to find someone with a much better scan tool to pull the tranny codes instead of just generic powertrain ones....still transmission control system malfunction code on a manual tranny? anyone have any ideas even a shot in the dark since it might be a bit till i find a nice scan tool to borrow
Old Apr 15, 2011 | 07:25 AM
Lazy K's Avatar
Lazy K
Need more info. What engine? Is this the trans that came with the truck from the factory (check the door sticker trans code)?
Old Apr 15, 2011 | 10:19 AM
slipkorn34's Avatar
slipkorn34
sorry 5.4 2v should be stock driveline all the way to the wheels
Old Apr 15, 2011 | 10:45 AM
Lazy K's Avatar
Lazy K
With it being a gas motor any OBD2 code reader should be able to read transmission codes for the automatic transmission.
I would assume you are getting a false code as you have a manual trans. I would doubt that your PCM has any transmission programme in it at all.
Maybe use your code reader to clear the code and then check for codes again, if it comes back without any driving I would think either the code reader is throwing a false code or there is a bad connection between the reader and the port.
Just my opinion.
Old Apr 18, 2011 | 07:50 PM
slipkorn34's Avatar
slipkorn34
i cleared it the first time i read it and it came back about 100 miles later, but i havnt put the scanner on it yet to see if its the same code or not but ill check it when i can.(i wont have access to my scanner for at least a week so im going off the autoparts store one)
Ray West
May 1, 2017 03:17 PM
jffrymchl
Sep 28, 2016 08:49 PM
TrippyDaze
Modular V8 (4.6L, 5.4L)
Jun 22, 2016 06:21 AM
ndanielle1968
Apr 8, 2015 06:36 AM
Piolet
Apr 18, 2012 10:34 PM
