Programmable Ignition Key
Old Mar 19, 2003 | 04:23 PM
wesayso's Avatar
wesayso
Is there a way to disable the programmable feature for the ignitioin key? I bought a 1999 F150 with a chip in the key and only got one key. The ford dealership wants $100 for a duplicate!! Help!!
Old Mar 19, 2003 | 11:02 PM
steve83's Avatar
steve83
Some aftermarket alarm companies sell a unit to do it.
Old Mar 20, 2003 | 09:19 PM
dro man's Avatar
dro man
Tell us how they disable it if you can find out. I think they just tape a programed key to the transciver on remote starts. (but dont know for sure? )
Old Mar 20, 2003 | 10:30 PM
steve83's Avatar
steve83
I always assumed they installed a corresponding chip (based on info you'd provide) to do it. As long as you could get the PN for the specific key blank from Ford, they should be able to dupe it.
Has anyone ever investigated uninstalling the PATS so a normal key would work?
Old Mar 21, 2003 | 12:18 AM
charlez's Avatar
charlez
The PATS can be disabled. The only way is to have the EEC reprogrammed (reflashed) This is not something the dealer will be able to do. You would have to contact someone such as motorhaven.autoanything.com to do this.
As for the remote starter bypass modules....
Crimestopper sells a module that you don't have to leave your key in for it to work. I believe you use the key to program it once and it works from then out. The only problem is you would have to wire it up a bit different. The module is designed to only "activate" when a remote start is requested. I guess you could hook it up so it's on all the time.
(www.crimestopper.com - remote start acessories)
$100? wow that's pricey...
