1978 - 1996 Big Bronco
NO Start
Old Mar 19, 2003 | 11:10 AM
dknight's Avatar
dknight
NO Start
HELP...1989 Bronco. Just installed 351W, rebuilt engine. will not start.
Compression....150psi
Spark..... yes, good color
Fuel....40psi
How do I check if fuel is coming out of the injectors?
Old Mar 19, 2003 | 10:01 PM
steve83's Avatar
steve83
NO Start
Pour a little into the throttle body - if it runs for a second, then that was the only gas getting into the engine. Check for 12V on the red wire that goes to all the injectors and check for an oscillating ground on the other wire (one group has Tan/R & the other has Tan/Or). If you can stick a pin thru one of the tan wires, ground it temporarily, & get the engine to sputter, then the ground signal isn't making it to them for whatever reason. My engine had sat in a junkyard for a few months and I had to hold the second wire grounded for a few seconds to get the injectors hot enough to melt the goo inside them. They've been running fine for the past ~200Kmi.
