Are theses Moog?
Old Apr 10, 2011 | 09:59 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Are theses Moog?
I can't find a number to call, does anyone know if these are moog?
www.partsguyed.com
Old Apr 10, 2011 | 10:07 AM
mueckster's Avatar
mueckster
Look closely at the pics of the parts (click on it) in the full size image view. They are Motorcraft and Ford parts. Ball joints have grease fittings, however, unlike the OEM versions.
Old Apr 10, 2011 | 11:20 AM
bulla's Avatar
bulla
My upper oem ball joints had the grease fittings but my lowers did not. I purchased them about 2 months ago from our local ford dealer.
Old Apr 10, 2011 | 11:45 AM
Josh88Ford's Avatar
Josh88Ford
I have heard moog balljoints will wear out the axle cup so you will be unable to use any other decent balljoint. I put DANA balljoint in mine and mechanic said he has had the best luck with these. All greaseable(with schaeffers of course) but instead of doing a 90 fitting for the uppers, use a regualr straight and buy a slip end for your grease gun. Basically you slide it over the zerk, not push. Otherwise 90 degree zerks will eventually hit your axle.
