drw rear brakes help
Old Apr 9, 2011 | 11:34 AM
danedaddy25's Avatar
danedaddy25
AGHHHHHHH!! please help, i dyin out here! '05 6.0 350 drw . doing brake rear rotors and pads. any general advice welcome, specific torque specs desperately needed. rotor to hub, fancy hub nut (ratcheting deal), axle shaft to hub, caliper bracket to "vehicle", caliper to bracket. thousand thanx in advance.
Old Apr 9, 2011 | 12:04 PM
rdunagan's Avatar
rdunagan
just make sure they are good and tight thats what i do havent had a problem at all. just take your time and i use a C clamp to push the caliper piston back in
Old Apr 9, 2011 | 02:56 PM
danedaddy25
problem is if i tighten the nut that holdes the hub, rotor, and bearing on, wont turn- should be some proper procedure, yes? no offense, but that is why i like specific numbers to go by- i.e. torque specs for everything. maybe i'm being too ****, though.
Old Apr 9, 2011 | 03:56 PM
Zmann's Avatar
Zmann
try this thread
Dana 80 Axle Bearing Torque?? - Diesel Forum - TheDieselStop.com
Old Apr 9, 2011 | 07:29 PM
danedaddy25
thanks zmann- looks like that is as close as i can get to my '05- followed it all except for the 90 degree back off and dial guage- instead used a "tighten then back off 7 clicks" method. doing front pads and calipers tomorrow and will let you know how it goes after i hook up my 10,000 lb enclosed trailer and hit the highway at 85 mph! later!!
Old Apr 10, 2011 | 08:09 AM
Zmann's Avatar
Zmann
I guess your Dana 80 has the same retention nut as the SRW Sterling ? I was not that fond of the ratcheting deal myself
Old Apr 10, 2011 | 11:20 PM
danedaddy25
Must be but i guess all we can do is believe in it a little bit more each week, huh? lets hope this is the last of stinkin rear ends and funny looking nuts!!!! honestly, now i've got to focus on increasing the fuel economy- thanks 2008.
