trans swap
Old Apr 8, 2011 | 09:50 PM
jebstruck's Avatar
jebstruck
trans swap
taking a 4spd out and installing a 5 spd zf in a 85 , would like to use the flywheel but need help finding a clutch disc for the combo.any help would be nice .
Old Apr 8, 2011 | 10:20 PM
oreocreaming's Avatar
oreocreaming
before posting, please do a search first. at least look at the posting on the first page that deals with the same swap your doing.
Old Apr 9, 2011 | 08:38 AM
fellro86's Avatar
fellro86
Not going to be able to reuse the 4 speed flywheel due to different depth and position. If you want to stay single mass you have to get the conversion flywheel, and at that rate, might as well get the whole set. Be forewarned, you get a rattle at idle that bothers some due to the lack of vibration dampening, and the noise comes through the transmission, making it seem that it is failing or such.
Old Apr 9, 2011 | 01:30 PM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...to-zf5-or.html Also have a read through this active thread. Plenty of good info.
Old Apr 10, 2011 | 10:10 AM
jebstruck's Avatar
jebstruck
thank you for the info on the flywheel .i will save up some money for the solid flywheel kit. thanks agian
Guntar
Feb 8, 2010 09:19 PM
mike390
Feb 20, 2005 05:52 PM
low03150
Modular V8 (4.6L, 5.4L)
Jul 29, 2003 11:13 AM
clint69
Jan 21, 2001 09:41 PM
