EEP!!
Old Apr 8, 2011 | 06:52 PM
blackmajikf100's Avatar
blackmajikf100
EEP!!
just put thrush turbo mufflers on my truck from glasspacks it never did it before but now i have rocker ticking and the carb pops when its revved or under load or when i barely touched the gas
Old Apr 8, 2011 | 07:07 PM
tmcalavy's Avatar
tmcalavy
too much back pressure...just like when you have gas
Old Apr 8, 2011 | 07:54 PM
blackmajikf100
any way to fix it without removing the mufflers.... cause its got dual 2 /14 inch pipes no cats no resignators and it ends like 2 feet behind the cab
Old Apr 10, 2011 | 07:59 PM
orich's Avatar
orich
Post
I'd start with a compression test. Also check the vacuum to see if any internal problems could be the cause. Like flat cam, burned out exh. seats or valves. If all good then move on to distributor,wires,plugs, & carb. an so on..
orich
