help is need! (like always)
Old Apr 8, 2011 | 11:59 AM
zakk's Avatar
zakk
so i replaced my axle seal a few weeks ago because it was leaking i pretty positive i did everything correct, but now after my 800 mile trip back to you utah it has started leaking again. so i will be replacing it tomorrow and ill do the fluid in the axle this time too. so what weight is the axle fluid that i need? and can someone show or tell me where the breather hole or whatever it is on the axle is that is know to get clogged? i have the 10.25
Old Apr 8, 2011 | 12:00 PM
zakk's Avatar
zakk
help is needed* not need haha
Old Apr 8, 2011 | 12:12 PM
BlueOvalBud's Avatar
BlueOvalBud
The breather tube comes off the hollow bolt that holds the brake hose to the rear axle. On my cab and chassis, it runs straight up to the frame and has a fancy cap.
I didn't know they were commonly clogged.
But I do know that when I took the brake hose off my Dana 70u (when I put the 10.25 in my truck), I had to chisel out hard-packed dirt/grease from that hollow bolt. So I guess it's the same idea with the 10.25 getting clogged.
Old Apr 8, 2011 | 12:37 PM
zakk's Avatar
zakk
oh okay ill check it out when weather lets up. how about the weight of the gear oil do you know?
Old Apr 8, 2011 | 12:42 PM
BlueOvalBud
I drained mine, scraped the mating gasket surfaces, laid a bead of RTV, bolted the cover on tight, and filled it up with standard 80w-90 Gear Oil.
There are only 2 gear oils that I know of at the parts stores. 80w-90 and 75w-140.
Capacity? I don't know...I was using older semi-full/semi-used bottles left over from other jobs...
Old Apr 8, 2011 | 12:47 PM
zakk's Avatar
zakk
oh okay sweet thank you sir
Old Apr 8, 2011 | 03:32 PM
snaponprofile's Avatar
snaponprofile
This went in my axle, it has the limited slip additive added.
Old Apr 8, 2011 | 03:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn
On my F250, the dealer changed the axle seals 3 times on warranty as they always leaked.
I told them what it was the first time. Check the vent... nope, they liked better changing seals. The 3rd time, I stood right next to them in the dealers garage and watched them do it. And I made damn sure they looked at the vent, sure enough it was clogged.
Never had a single leak from both axles on the truck since then! Seals have over 300k miles on them! Axle seals leak shouldn't happen, it's all about venting. As long as the axle can vent, they last for ever! Very very rare you'll see a seal leak that has had a good vent.
That's one thing not alot of people know, and even less check. I'd check mine once a year (after each winter), I'd remove the rubber hose off the axle, clean it up, check the cap, and re-install.
Dad
Old Apr 8, 2011 | 06:41 PM
snaponprofile
3.7 quarts go in the 10.25 rear bud.
Old Apr 9, 2011 | 01:21 AM
zakk's Avatar
zakk
sweet thanks guys! and John do you know if i unplug the vent if it is plugged will it stop the leak or do i need to replace it sense it already caused it to leak
Old Apr 9, 2011 | 10:40 AM
IDIDieselJohn
Just take the whole hose off and shoot some compressed air through it, and water and check make sure the cap on top isn't jammed or clogged.
Old Apr 9, 2011 | 11:07 AM
zakk's Avatar
zakk
im wondering if it is plugged and then i unplug it will i still have to change the seal?
Old Apr 12, 2011 | 07:10 PM
eatont9999's Avatar
eatont9999
Dad
My rear end is leaking where the drive shaft connects to the differential. On the driver's side axle there is a cut-off rubber hose that looks like a vent. Could that cause the leak I have? I just replaced the oil and seal a few weeks ago. Let me take some pictures before the sun goes down.
Edit: seal for the cover.
Old Apr 12, 2011 | 07:15 PM
IDIDieselJohn
Your talking about the front pinion seal. Yes a clogged vent will also cause that seal to leak also.
When a vent gets clogged, the pressure that builds inside will have to release somewhere, and it's gonna take out the weakest seal most of the time.
Old Apr 12, 2011 | 07:44 PM
eatont9999's Avatar
eatont9999
You can see where the gear oil is being slung onto the fuel tank.
I haven't driven the truck in two days but after a drive, there is gear oil on the knuckle closer to the diff.
You can see the darker colored metal from oil and dirt.
Here is the hose that has been cut or fallen off. A vent maybe?
Another view of above.
Vent hose again.
More perspective.
