F-250 Purchace Advice
#61
#62
An F-150 is fine as a daily driver and pulling a trailer of that size. You'll barely even know it's back there. I was pulling a 7200 lb., 30 ft. travel trailer with my 2006 F-150 4x4. It did the job, but the engine struggled. Typically, I would be doing 3000 RPM at highway speeds and getting 6-7 mpg. I just took my travel trailer out today to test the towing and set up the brake controller. I was cruising between 1500-1800 RPM and getting 16 mpg in tow/haul mode. This 6.7 diesel is a dream come true. But if you are only towing motorcycles, an F-150 is all you need. Most cars will pull that load.
#63
Hey im about to deploy and looking at differnent trucks.. Have about 30k saved up before deployment and buying myself a toy when i come home..
Choices are f150 ecoboost, raptor, f250 KR superduty.
Ive already priced out the f150's but curious how much off msrp i can get an f250 as military and if i go through the usaa bank? Fully loaded KR by the way
#64
Stay safe on your deployment and thanks for your service!
#65
