So I used a port a power to pressure up my oil rails and here's my results. I'm looking for someone who has done this to compare notes and knowledge. Cause I ain't got a clue what I'm looking at!!
Could be a bad injector o-ring too. When the pressure is higher it may bleed down, then when the pressure is reduced it holds. You have checked the hand pump to make sure it holds pressure right?
Yes it would and it will! I was pressed for time and needed my truck for today. If I'd of had the vc's off I'd of tore into it to far. Thanks fog the thought.
