It is standard on the FX4 and you can also get it if you order the available new Off-Road Package.
Sorry, I meant the "manual" locking part. Being able to pull the **** out for rear lock in 4x2 and 4x4 modes. I thought everything except the Raptor will only engage the rear locker when 4x4 is selected.
^^^ That is true. Only the E-locker in the Raptor will engage in 2wd. I've seen on another forum where people swap the Raptor parts to their F150s to make the E-locker work in 2wd. The E-locker disengages at 25 mph in high range in 2wd or 4hi so it's still useless to me.I'm still planning on putting a Truetrac in my FX4.
Given a choice between the Off-Road Pkg. with the E-locking differential or the regular 4x4 with the optional limited slip, which would you choose? I know the Off-Road Pkg. has other options ie. skid plates, but I could have them added later if I chose the limited slip.
In the thread below, an individual figures out how to make it work above 25mph I believe. It's later in the thread and he lists the part/part numbers to make it work if I remember correctly.
EDIT: I just re-read some of the later posts. Looks like it's working for some and not for others.
Ya from what I read I didn't think it was working above 25mph.Even if it did work a locked rear would be scary on slippery snowy roads.
I just need to find out if swapping in a L/S carrier would mess up the traction control or anything else.
