stutter after startup
Old Apr 7, 2011 | 05:03 PM
feedle's Avatar
feedle
I've noticed recently that after a cold startup, when I am taking my foot off the clutch and starting to accelerate, the truck stutters a little like it is going to stall, and I have to step on the gas a little more to keep it going. This will happen once or twice, just when i start moving from a stop, and then the truck will run fine. Does not happen at higher RPMs.
Any suggestions on what this could be??
1993 f150, 4.9l, 5-speed, 4x4.
Old Apr 8, 2011 | 07:30 AM
Lazy K's Avatar
Lazy K
Are the spark plugs good and properly gapped? Are the plug wires good?
Is the fuel filter recent?
Old Apr 8, 2011 | 08:15 AM
feedle's Avatar
feedle
After posting, I realized this problem seems to happen every time i start from a stopped position, up until the engine gets up to normal running temp. Not just the one or two times i said before.
i replaced plugs and wires probably ~2 years ago. havent touched the fuel filter in the 2.5 years of owning the truck. Probably hasnt been replaced in while. Wouldnt these things cause an issue even after the motor's warmed up?
Before I replaced plugs and wires (2 years ago) the truck was stuttering during acceleration at any time, warm or cold... my current problem is a little different in that its only happening (at least that i can tell) when the engine's cold.
Old Apr 8, 2011 | 08:17 AM
feedle's Avatar
feedle
but you're right... those things would be a good place to start looking at least. A little tune-up couldnt hurt.
Old Apr 8, 2011 | 11:27 AM
jaymzway's Avatar
jaymzway
check your cap and rotor as for this happend to me rite before it melted the rotor
check your cap and rotor as for this happend to me rite before it melted the rotor button I also replaced the ingnition control modual as well case there was some damage there in this case it retards your spark and causes bucking and backfire and hesitaion and stalling and you will notice it will only get worst good luck to ya!
Old Apr 9, 2011 | 06:38 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » Engine Coolant Temperature Sensor (ECT) Maybe test the ECT as described in this link.
Old Sep 24, 2013 | 09:53 PM
jaymzway's Avatar
jaymzway
OR MAYBE I CAME HERE FROM GOOGLE AND SO I WASNT ABLE TO SEE THE REST OF THE LINKS HERE BUT OK YOU SAY SO BRO!
circa55
Jun 30, 2015 05:50 PM
05F250DSL
May 18, 2015 04:34 PM
TheBigBee
Sep 22, 2014 03:15 PM
3drhino
May 8, 2014 05:35 PM
BillyBob69
17
Apr 5, 2012 04:14 PM
