Blue Oval Saga Pt. II-Michelle
#451
My god those FMO's are huge lol as far as exhausts go do i hook them all up after the cat? and i personally was thinking maybe some just straight dual exhausts but those would come straight from the enigne right? which means no cat and probably more work since i would have to find places to attach the pipes to the truck
#452
#454
If you get a shop to do it, a set of straight pipes, and those FMO's could be put on, in about 3 hrs...And for about $400-ish....Counting the pipe...
#455
i moved from home which was a shop and any tool you could dream up to a house in the city were at most i have a concrete slab and basic tools, so with straight pipes i would just cut every thing down get two FMO's and some pipe? sounds easy enough wish i had the cutting torch though...i suppose i could get a sawsah from someone around here
#456
Just cut the OEM muffler out, and replace it with the FMO....Simple, and easier to do...And can be done with clamps....
Plus, if you have emissions testing, you can pass...
#457
Not yet. I have a cracked passenger side manifold, so I'm just going to go with Long Tube headers, a Hi Flow Cat, then probably a Thrush Turbo Muffler. Going to have duals going out at 45's.
#458
#459
#460
4-20-2012 Michelle Update
- Semi-Wired in my "new" to me stereo...
- A friend of mine gave me 3-10" MTX 4000 subs, box, and a 2,400w, 4channel Planet Audio amplifier...
- Wiped my engine bay down, ziptied a few wires up out of the way...
- Cleaned all my windows really good.
- Did my monthly vehicle inspection
#461
The highest items I've paid for was the Hood, Bed Tarp, and Lights...
As for the exhaust...A Sawz-All, and some clamps, and you're in business...
A lift is preferred...Allows more room...
The Borla Stingers are a lot quiter than the Flowmaster Outlaws...
*The FMO's are basically coffee cans...in size...lol..
#464
Read through these:
1992 Ford F-150 Old Instrument Cluster Work pictures, videos, and sounds | SuperMotors.net
I did the walk through for just this reason. To get the color you want either use colored LED's.
#465
Read through these:
