Synthetics Diff oil?
Old Apr 7, 2011 | 10:08 AM
USMC1968's Avatar
USMC1968
Again with a newby post.
I want to change out the differential oil on my 1994 Motorhome based on an E350 7.5L 460. It has the Dana rear 4.10 ratio. I bought it used with 38,000 miles on it and probably has never had it changed. Since it is a motorhome and heavy should I use Synthetic GL-5 SAE90 hpoid oil like Motul or go heavier than 90 since it is a MH?
I have the Haynes manual but cannot find anywhere what the capacity is back there. Thanks again
Semper Fi
Old Apr 7, 2011 | 11:27 PM
jimbbski's Avatar
jimbbski
The SAE 90W should be fine. I usually use Mobil 1 75-90W since it's easy to find at the auto parts store.
Old Apr 8, 2011 | 05:21 PM
SilverE350's Avatar
SilverE350
75W 140 synthetic is what I would use. Buy it a Wal Mart.
Old Apr 8, 2011 | 06:22 PM
USMC1968's Avatar
USMC1968
Thanks! I was wondering about going heavier since the specs from Ford are for the Van, not for the MH conversion which adds quite a bit more weight.
Old Apr 8, 2011 | 09:15 PM
SilverE350's Avatar
SilverE350
If your Diff cover doesn't have a from plug, just pull it off and clean doth sides with a scraper then Brake Cleaner and use Black Silicone to seal it up. Following the directions on the Silicone.
And thank you for your Service.
polarlys
6.7L Power Stroke Diesel
16
Sep 11, 2016 01:55 PM
whomrig
1997 - 2003 F150
May 29, 2016 09:55 PM
littlejohn64
Mar 30, 2016 05:01 PM
joe blow
Sep 30, 2015 05:41 PM
SweetPete531
3.8 & 4.2L V6
Sep 23, 2015 07:37 PM
