Also, the deformed seal looks like it's on backwards. The bevelled edge should face the other way so that it fits inside the the poppet valve sleeve....
I wonder about that myself. It sort of looks like the seal was pointing the correct way (bevel towards the bowl) when it began life but eventually smashed itself into the rim of the poppet valve so it looks backwards when I eventually pulled it out. I wasn't sure to be honest. When I put the new parts in from the rebuild kit, I assembled the seal per a photo that you sent me at one time. (see below). Did I do it correctly?
You put it on right during rebuild but the pic of the deformed seal looks like it was put on backwards during a possible earlier rebuild, per my edit. Just looks like someone put it on wrong before you got to it.
The pic of my original seal shows how it wears when the seal is oriented properly.
Chris, did you replace the fuel pump? If so, was it by chance an airtex unit. When my FASS pump died back last fall I replaced it with a stock Airtex unit from Oriellys, and was suprised at the amount of pressure the new pump puts out. the pump itself is stamped with 110psi max output, and with NO orifice in my fuel system it will maintain 50psi, with an .0036 orifice (thats what came with my DFA kit) my truck sees 95psi, with only a 7#drop under WOT. Now of course I dont have a fuel bowl anymore so I dont have to worry about blowing out the o-ring on the lid and creating a leak, but my truck seems to like the higher fuel pressure.
Brandon,
Where is the orifice located on your truck? How does it increase pressure? I am not familiar with the fuel bowl delete systems and how they work so I am trying to learn a little bit myself here.
Brandon,
Greg, I'll try to explain it so you can get a picture.
1 feed line off the tank to (10micron) inline filter to fuel pump then to a 3micron spin on filter then1 feed line from 3micron filter to enigne bay that runs into a Tee fitting, and then 1 line off each side of the Tee to the back of each head. 1 line off the front of each head to another Tee fitting, Orifice on the outlet of the Tee fitting going to a single return line back to the tank.
by filling the heads from the lowest point any air is then sent out the return lines on the top(highest point)
unfortunatley i dont have a really good pic to post up that doesnt look like a bunch of random hoses..... so i hope you can follow my explanation.
I have always been curious now much fuel is returned to the tank so it will be real interesting to see what you find if you try bypassing the return line.
That varies. The fuel not being used by the engine goes out through the FPR back into the tank. When the truck is off and the key gets turned on, once pressure is up all the fuel goes out through the FPR. At idle the engine uses some, at WOT the engine uses more. I'll try and get a flow rate with engine off and at idle for you when I do this.
Yes, but about 3 years and over 100,000 miles ago so unless a failing pump suddenly causes a spike in pressure, I don't think that's it.
How long have you been running the higher pressure Brandon? I've heard it can be hard on injector internals, but that's just something I read on the internet.
3 years at 75PSI, and for the past 7 months at 95psi.... as far as being hard on the internals, dont T444E (non ford) run at 80 psi from International. That was something I read somewhere, but I cant put my finger on which site it was.
Yes. Perfect explanation, thanks!
I get it now. The orifice restricts the return flow, so that is why your pressure is so high. No orifice, no restriction and less pressure. Have you experimented with different orifice sizes?
Based on your readings, then it sounds like the return flow on Chris's truck is restricted as well...hence the similar fuel pressure readings. I suppose Chris could remove the spring from his FPR and see if his pressure falls to 40-50 psi range. That would highlight the FPR as the culprit. Correct?
Mine suddenly stopped and went back to normal for no reason. I believe the above diagnosis is correct so I ordered a FPR rebuild kit from Bob and will install the parts when time allows since I'm no longer having any issues.
I can not find my "thread/post" about similar issue. My gauges reads 68/69 psi, all day long, but a few weeks back, i noticed at idle, from time/time, it would spike to 80psi. Once i needed fuel, went to chevron, and since 76, and that spikes' gone. The orig fuel in there was from Arco. Havnt gone back, think i'll pay the extra 5 cents per gal.
