Superglide 5th Wheel Questions
I looked over the 5th wheel I purchased (It's a Forest River "Wildcat") and there are no manufacturers markings or any numbers on the king pin anywhere. From the measurements I took, it appears to be a Lippert 1621. I see they have a Quick-Connect plate for that specific make, which seems to be a simple slip on no drill/bolt application install. They also have "Multi-Fit" plates that fit a wider range of kin pin dimensions, but I wasn't sure if these multi-fit plates required any drilling, welding, or bolting like the "Universal" capture plates do. Can anyone shed some insight on this? I mean I'm reasonably sure its the Lippert 1621, but I would prefer the Multi-Fit plate because of the flexibility just in case it isn't a 1621.
I bought the trailer from a lady who lives approximately 200 miles away from me and I left it there with her for the time being. My Superglide is supposed to arrive early next week, at which time I will have it installed and then drive back down to where the trailer is parked and bring the trailer back home with me. I just didn't want to be in a situation where I drive 200 miles down there to get the trailer and I have the wrong capture plate and need to drive all the way back to town and order a new one. I would prefer the slip on type installation the Quick-Connect type plates offer because I won't have any equipment available to drill, bolt, or weld and the area is in a rural part of Alaska where I doubt I can find a mechanic to do the work for me.
Any info would be appreciated!!
Eveything is one piece, works exceptionally well and I did not have to purchase parts to put it all together.
Just an alternative to what you are looking at. I don't know anything about the superglide.
Maybe this will at least give it a bump.
I have pics of mine in my album.
I'm fairly certain I could get by with the manual as I always try and reserve pull through camp sites and I try to plan my trips as best as possible. However, there are those unexpected times where your trailer ends up in the damnedest positions. Our gas stations here in Alaska are like damn war zones in the summer time absolutely packed with RV's, boats, and trailers from tourists during fishing season. You have to make some pretty crafty turns getting in an out of there, figured the slider would be great for situations like that.
As far as the Multi-Fit capture plate, I did some rooting around and it seems the newer #3565 plate replaces the older Lippert plates and works with all Lippert pin boxes. Furthermore, it is a relatively straight forward no drill, bolt, or weld installation procedure so it looks like that is the one I'll need. If everything stays on schedule, I should be getting my Superglide installed on Tuesday/Wednesday and drive down and pick up my 5th wheel on the weekend. Too bad its another month and a half before fishing season starts
Since my 5er is new and comes with a more turn friendly front to it. I really don't even have a need to move it to the rear, except in exteme circumstances
Trailers here in Alaska almost always sell for significantly above NADA book, an Alaska "premium" if you will. I look at the low prices you guys in the lower 48 can pay for a new trailer and it boggles my mind.
As far as the capture plate goes...as long as your measurements are correct you should have the correct plate.
What model of Wildcat do you have? I have a 2005 31qbh. If yours is the same I'm sure I could get measurements and see if they are the same as yours.
I assume you have seen this link, but I'll post it anyway. I would avoid the Universal plate if possible. I can have my capture plate on and off in 30 seconds. Let me know if I can help.
http://www.pullrite.com/pdfs/QCCP_Fit_Chart.pdf
PullRite has a SAFER, STRONGER, BETTER designed hitch for you
Yes, that is the spec sheet I referenced while measuring. Both myself and the shop doing the hitch are reasonably sure its the Lippert 1621. My installer ordered the specific Quick-Connect plate for the 1621 pin box, and I ordered the Multi-Fit plate myself. It would suck ***** to waste the 3 hour drive down there, have the wrong plate, drive all the way back into town, order the new plate, then drive back. I figure when I drive down there it will be better to have both of them just in case, but I can just return whatever one I don't end up needing. I got absolutely raped on the shipping (UPS shipping for the Multi-Fit plate ALONE was 65 bucks) so that's money I'll lose when returning it, but it would be cheaper than the fuel cost for a 400 mile round trip in the event of a wrong plate.
As for what I'm worried about now:
I was all set to get one of the louvered V style tailgates just for ease of hookup and then I remembered I had the (factory) backup camera. I'm not quite sure what that's going to do when installing a replacement louvered tailgate. I would prefer keeping it so I'm going to try and get hitched up with the tailgate in the down position. If I end up having to have my spotter lift the gate while backing up I'll end up going with a louvered gate.
I'm also concerned about having the necessary clearance over the bed rails in my F250. My truck is bone stock as far as suspension goes, but it sits pretty damn high for a stock truck. The lady I bought it from was towing it with a big *** CTD Ram 2500 which I think would be at a similar height to my truck but I can't say for sure.
And as far as lubrication, I was all ready to order some "Slip Plate" as I've been recommended by others while doing some research, then I read the Pullrite owners manual. It says if your hitch is manufactured after Nov 2009 it has plastic way plates which don't require Slip Plate at all. I'm waiting to see if I get a newer hitch or if I get some new "old stock" hitch with the metal way tubes before ordering some Slip Plate.
I'm looking forward to finally going down and picking it up and seeing how the maiden trip home goes. It will let me know what I need to adjust (e.g. pin box height) before fishing season starts. Once I get her back into town she will be parked until Memorial Day weekend (first salmon fishing weekend for me) and then she will be out every weekend through October (I love fishing for Silvers when the snow is falling in October. Absolutely amazing
j/k yeah this one is our first and we learned that two adults one grandson and three small dogs is pretty tight in a 28' don't believe the ":sleeps 8" marketing hype....Haa......So we will camp out more this year and are seriously looking to upgrade to a toy hauler. Take grand kids, leave dogs in the back and will be my contracting home in 27 months..woo-hoo......
Anyway always excited for a camper that is looking to reduce stress by camping out and meeting new and friendly folks.......take care.....
C-man....
