Modular V10 (6.8l)
Blown plug , not my fault !
Old Apr 5, 2011 | 05:25 PM
rokhedjo's Avatar
rokhedjo
OK, I know there has been many threads on this subject. I wil just say that I installed the spark plugs at 100k miles, anti-seize, 20lbs ft torque.#3 plug ejected @ 131k miles, checked the rest of the plugs, and they are all tight. All I have to say is IT AINT MY FAULT ! I did everything right by the book ! My suggestion is maybe we need to recheck the torque after a certain mileage after installation (15k ?) . Bought the time sert kit , BRAVO ! awsome kit ! I am going to make a carbide reamer bit for the kit though, ( I have the resources ) It will make the cut much easier. Back on the road and fingers crossed.
Old Apr 5, 2011 | 05:47 PM
mwsF250's Avatar
mwsF250
Hmmm...
Did you buy the truck brand new?
Old Apr 6, 2011 | 04:37 AM
BigPigDaddy's Avatar
BigPigDaddy
Originally Posted by mwsF250
Hmmm...
Are you thinking the hole may have been damaged prior?
Old Apr 6, 2011 | 08:18 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
"By the book" it's 14ft/lbs
Not that it had anything to do with it, "just sayin'"
To anyone else doing plugs, always check the plugs you take out for aluminum on the threads, and definitely try to inspect the threads in the head with an inspection mirror.
Old Apr 6, 2011 | 02:37 PM
mwsF250's Avatar
mwsF250
Exactly. All it takes is one boo-boo. Weakened threads may hang on for a long time, but eventually they fail.
Old Apr 6, 2011 | 02:40 PM
mwsF250's Avatar
mwsF250
And 20 with anti-seize (lubricant) is like 30-40 dry, but even that should not be too much.
