Little stamped steel tabs in 351M/400 rockers?
What are they? Do I need them? I accidentally torqued down my rockers just after cleaning them (no oil), and the little stamped steel tabs that go between the bolt head and the big thick piece that inserts through the rocker caught against the bolt heads, and alot of them deformed to some degree. I know they're in there to direct the oil in some capacity, but do I need them? And does it really matter if some are bent?
AleX
AleX
Ah, well that's kind of what I figured after some research. Companies that reproduce the rockes fold over a little tab on the rocker's tip to redirect the oil jet it seems, so I guess ya, it is necessary. Good advice generally too.
Guess I'll grab some spares, thanks as usual! AleX
You may not get a response to your question. This thread is 14 years old, and the OP hasn't visited here since 2019.
Rob in Idaho
Oct 21, 2025 11:00 PM
Mater1964
May 7, 2025 08:28 PM
stangman67
Dec 5, 2003 03:03 PM
cewebb4
Aug 10, 2003 05:50 PM
