Sponsored by: Real Truck
Voltage draw one battery
Old Apr 5, 2011 | 01:50 PM
mackman's Avatar
mackman
Question Voltage draw one battery
Has any one come across a drain on only the left batt on an F250SD diesel ?? Have tryed to find by removing fuses and relays but found nothing,was under impression all circuts where protected . Is there another fuse panel besides hood and under dash ? Wireing diagrms only show fused circuts . Help
Old Apr 5, 2011 | 02:25 PM
mnpowerstroke99duty's Avatar
mnpowerstroke99duty
I think on my 99' truck the driverside battery cables only go to the passengerside battery no where else.If yours is the same. I would say maybe the battery is bad or going bad thats why it gets drained down.
Old Apr 5, 2011 | 03:26 PM
dchamberlain's Avatar
dchamberlain
It's not possible for there to be a drain on just one battery, unless the cable connecting the two is damaged or the grounds are damaged.
I would check and clean all the cables and grounds, then disconnect, charge and load test each battery separately.
Old Apr 5, 2011 | 10:25 PM
mnpowerstroke99duty
I agree if you have something draining the battery it would drain both batteries.I'd do like dchamberlain says and see if you can figure it out.
Old Apr 6, 2011 | 06:51 PM
jmassimilla's Avatar
jmassimilla
Had a similar problem a couple of months ago. Both batteries were draining if the truck sat more than a couple of days. Drove me nuts. I finally fully charged both batteries and load tested them individually. The passenger side battery failed the load test (just barely). I didn't think to check the batteries because they were only a year old. I replaced both of them and have not had any problems since. BTW, the batteries are tied together, 2005 F350 C/C.
Old Apr 6, 2011 | 11:17 PM
twags6's Avatar
twags6
I had the same problem too this past weekend. The drivers side battery had a bad cell and was only holding 10.5 volts, which was draining the passenger side one down. Two days later, that one died too. Get them both replaced before you take out your alternator too. It'll overwork itself trying to charge them.
mrl390
Large Truck
Aug 24, 2013 11:03 PM
boss66
Aug 24, 2011 05:00 AM
cmbroo1
Sep 28, 2010 04:55 PM
Hotairjunkie
Electrical Systems/Wiring
Jul 9, 2009 11:03 PM
FD5150
Dec 11, 2008 08:18 PM
