I am looking for a front receiver, mainly so I could plug my winch in.
It needs to be an under bumper style as I have large auxiliary lights where the OE fog lights normally go. Not willing to give those up. I do not have an air dam, and truck is lifted a bit.
I have found the Warn 38450. Are there any others?
I think the Curt C31014 would work because it mounts to the underside of the frame rails. The installation instructions indicate that it does not interfere with the air dam.
Thanks! I'll check it out.
Quite a bit less $, but I don't think I have a blocker beam on my truck. I'll have to crawl under and check if the holes are there in the frame already, or easily drilled.
It appears I do not have a blocker beam on my truck, as things on my truck look completely different from the install instructions on the Curt...
I don't even see holes or blank areas to drill to fit the Curt. I guess that's why it says ONLY for trucks with blocker beams!!!
Anybody have experience or knowledge about how to make it work?
