99-04 super duty leaf spring lift in 71 f250
#436
#437
With weight on the plumb bob will be in front of the diff cover flange
#438
Almost forgot test fit my transfer case for the first time since I rebuilt it. Since I clocked the t case for more ground clearance. My twin stick linkage was hitting the crossmember before it was in the right spot so I had to notch the xmember for clearance and reinforce it. Man I wish I had a pipe bender and notcher. I'd be doing everything in tubing.
Can't wait to be done painting the underside so I can mount the t case for the last time.... Maybe
#440
#442
Thanks Jeff good to we your back. I just hope I can keep getting shop time in and not get side tracked on other things.
Yea as I was designing it I wanted to make sure it wouldn't be to bulky and get in the way of anything if I need to do any repairs. If I got a hole in my oil pan on the trails it would be really hard replacing it if I had to hoist up the engine.
#443
With getting caught up on the updates and getting out to work on the truck I forgot to post up pics of my X mas present like I promised I'd do. I finally got it 2 weeks ago whatta you's think? Redhead steering box fully rebuilt, machined for the needle bearing upgrade, ported for more flow for the hydro assist, drilled and tapped And custom paint.
This things going to look bad a** mounted on the frame rail
#445
Thanks Crazed. Thanks to Gavin, Christmas, and my credit card I have a home PC for the 1st time. Just always used the computer at work. I must be more of a gearhead than I thought. Seeing the pics of the redhead got my testosterone pumping. (pun intended but still true)
#447
It was a pretty penny for sure but if it performs the way it looks it's money well spent. I sent in my own steering box and avoided the $300 core charge. It came out north of $500 after you pay for shipping to and from them. If you don't need it drilled/tapped, Ported and custom paint it will be somewhere in the $400 range. If you send in your box and avoid the core charge.
#448
#449
Yea he sure did. Waiting another 2 weeks after Santa came to give me my main present was worth the wait. The GF ure does know how to spoil me professional indeed they are One of the best if not the best place to get your steering box done by.
#450
Been doing some undercoating and painting done the past week I'll have to post some pics of progress when I sort them out. I picked up some more goodies. I came across this vickers hydro pump, adapter plate and gear from a guy. It uses a different adapter plate then the other pump I got. So now I'll have to do some searching for what pump I want to run and go from there. Also got these awesome cummins lift pump block off plates. Nice personal touch to bad it's in a area you won't see it easily.
The vickers is 2 1/2" longer then the other hydro pump setup I have.
Purty
Purty
