welding crossmembers
Old Apr 3, 2011 | 09:06 PM
lasthighboy's Avatar
lasthighboy
I have a 77 f-150 i plan on doing a frame off resto on. I was wondering if i should weld the crossmembers to the framerails while i have it stripped down to stiffen the frame up a little bit. It is a 4x4 but wont be used hard offroad. just a nice fairly stock driver. Is welding it worth the effort? Or does the frame need to be able to flex on the rivets? I will not be boxing the frame, so will it put too much stress on the welds and cause them to crack? The frame appears to be solid so there will not be any repairs or anything where i will be removing the factory rivets. Just wondering if it is a good idea to add a little stiffness or not. thanks.
Old Apr 3, 2011 | 09:23 PM
78 PEB's Avatar
78 PEB
I wouldnt reccomend welding them............why would you want to?
Old Apr 3, 2011 | 09:42 PM
hasteranger's Avatar
hasteranger
the factory welded some crossmembers and riveted the others. I'm sure they had a reason for it. Some on this forum say never to weld a frame. I disagree, but at the same time, I don't see any advantage to welding the crossmembers and it is an excellent opportunity to weaken the frame if your welds aren't perfects. I do hate the factory rivets... grade 8 hardware works fine as a substitute.
Old Apr 3, 2011 | 09:55 PM
JustBlaze's Avatar
JustBlaze
They did it on trucks for Das Bronco but on a street truck I wouldn't go through the bother. They did it to stiffen it up for offroading.
Old Apr 4, 2011 | 05:33 PM
ChaseTruck754's Avatar
ChaseTruck754
I agree with taking the rivets out and replacing them with grade 8 bolts (I do this on mine with fin thread, "shanked" bolts) rather than welding them.
Take them out, paint, powder coat or whatever you will be doing to both the frame and cross member and then bolt them back in. This assures ALL areas get painted.
Old Apr 9, 2011 | 08:58 AM
lasthighboy
I believe Das Bronco was where i got the idea. and i understand the concept behind it. Just wasnt sure if it was practical in reality or worth the effort.
Codeman894
Sep 4, 2016 04:22 PM
four-sixty-power
Feb 13, 2016 10:57 AM
ErrorS
1978 - 1996 Big Bronco
Aug 29, 2011 11:53 AM
byoungquist
Apr 14, 2011 03:44 PM
rmojo12
Sep 12, 2004 03:05 PM
