tire size question
Old Apr 2, 2011 | 09:10 PM
2005f-150's Avatar
2005f-150
tire size question
i got a older pull behind camper that is in dire need of new tires, they are cracked so bad i cant believe they didnt blow out on my way home(only 2mi and top speed of about 30) from what i can tell they are 7.75-15 what size does that equal to? i think i can get away with a "p" rated tire because the max gvw is 6,000lbs and it is a dual axle.
Old Apr 2, 2011 | 10:29 PM
TexasRebel's Avatar
TexasRebel
with a dual axle you might still want to get trailer tires. They will be a little more ready to take the wear involved in turns. Passenger tires are sometimes made with softer compounds which will wear faster and make sharp turns more difficult.
Old Apr 3, 2011 | 07:21 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Please do not get p tires if you are going to be towing on the same roads as me... At the very least get LT. You need the sidweall strength on a trailer.
Old Apr 3, 2011 | 07:59 AM
senix's Avatar
senix
no P tires...they are P on a TT.
Get LT or ST rated tires. They are rated for the job. Will take the twisting and turning and stand up to the heat.
Rated for the load. Get E-rated ones.
Old Apr 3, 2011 | 08:03 AM
2005f-150's Avatar
2005f-150
i never thought of the pressure of turning on the side wall. i will be getting a heavier tire, but what size do i need?
Old Apr 3, 2011 | 09:30 AM
Gearitis's Avatar
Gearitis
About a year ago I put tires on my 5er. It had the old 7.75 15's on there. I put Maxxis 225 70 r15's and they are an ST rated radial with E load range. I have pulled it over 6k miles, fully loaded and so far no problems. Discount tire had the best price at the time.
Many people put LT's on their trailers and I believe if you are going to pull it over 65 mph, that is the far better choice. ST rated tires are rated at 65 mph.
Old Apr 3, 2011 | 08:40 PM
2005f-150's Avatar
2005f-150
thanks for the info i wont be towing over 65mph tho. i will be getting a tire with a heavy rating for sure tho.
Old Apr 3, 2011 | 11:11 PM
Pete Roberts's Avatar
Pete Roberts
Yeah you'll want tires made for trailers. They are designed with thicker sidewalls and are made to withstand or take higher pressures for better stability under tow and will not bruise when turning etc...etc...and besides...if you run any tires on your trailer that are not designed for trailers and you have a problem...ie...a blowout or something and you cause a death or property damage you could be cited and sued, much less if your insurance company finds out...they won't pay...
Check it!
Pete
Old Apr 4, 2011 | 08:15 PM
Diesel Man 03's Avatar
Diesel Man 03
I have LT tires on my 5'er because that's how it came from the factory, my understanding is that ST tires are not better then LT's on trailers except the speed issue.
Fyrfyghtr
Dec 14, 2016 07:20 PM
bountyhunter1650
Jan 15, 2016 08:45 AM
martinbarrio
Nov 6, 2013 07:37 PM
midsouth
Mar 11, 2013 01:41 PM
hunterdeska1
Jun 20, 2010 10:08 AM
