first post
Old Apr 2, 2011 | 07:50 PM
tonybon's Avatar
tonybon
first post
just came across this site and it looks great. lots of good info. i have two ford trucks, a 94 f350 7.3l first gen powerstroke and just bought a 03 6.0l. my 94 has 250k and still runs great my 03 is DEAD thats how i found this form lol. just wanted to say HI and hope i can be of some help to someone sometime.
Old Apr 2, 2011 | 08:50 PM
wulfman's Avatar
wulfman
Welcome to FTE you came to the right place for 6.0s. This is where the smart people are and they are very helpful, what is wrong with your ride.
Old Apr 2, 2011 | 10:31 PM
tonybon's Avatar
tonybon
Will not start. Drove back from the store parked in the drive an hour later wouldn't start? Changed all the filters. Im getting oil pressure on the low end haven't had time to fully check everything. The only code is p2285 but this shouldn't keep it from starting.
Old Apr 2, 2011 | 10:51 PM
BLADE35's Avatar
BLADE35
sounds like hpop problems have you tried to pull the wire off the icp and see if it starts
Old Apr 2, 2011 | 10:56 PM
BLADE35's Avatar
BLADE35
dtc 2285 injector control pressure circut low this will cause a nostart
unplug the wire from the sensor and see if it starts pcm will use a default value
probably bad icp sensor or pigtail
check these and welcome to fte
Old Apr 3, 2011 | 12:02 AM
olfordsnstone's Avatar
olfordsnstone
HPOP check valve?
Old Apr 3, 2011 | 05:15 AM
wulfman's Avatar
wulfman
Blade you nailed it icp sensor, under turbo not bad to get to. There are instructions in tech folder on how to replace it you can do it in 2 to 3 hours. Have you had surging problems leading up to it. Mine never quit running just got light and 2285 code. They do leak oil yours pig tail must have gotten real oily to quit. They cost about 140 to 160, try partsguyed he is the cheapest.
Old Apr 3, 2011 | 12:33 PM
tonybon's Avatar
tonybon
Thanks all I pull 12 hour shifts and sometimes 6 or 8 in a row my next day off ill unplug the sensor and try that. Only had this truck for two weeks.
Old Apr 3, 2011 | 12:49 PM
BLADE35's Avatar
BLADE35
tonybon
pulled the wire is only good to verify you have good/bad icp sensor
if its truly low oil pressure on high pressure side your problem is deeper if pulling the wire thing dont work
Old Apr 3, 2011 | 12:54 PM
tonybon's Avatar
tonybon
It just had some work done before I got it. Was getting oil in the water. Replaced the tube and other parts. Cost like &700. At the dealer
Old Apr 3, 2011 | 01:04 PM
tonybon's Avatar
tonybon
If it starts ill replace the sensor. Do I have to pull the turbo to get this sensor? I know my way around my 7.3 but this 6.o is alot different
Old Apr 3, 2011 | 04:48 PM
cheezit's Avatar
cheezit
I do t-he sensors from the bottom. I find it easery to then doing them from the top. but thats me.
no need to pull the turbo.
Im sorry you own a 7.3
I hate them things
Old Apr 3, 2011 | 10:02 PM
tonybon's Avatar
tonybon
Thanks for all the help my next day off is wed. I plan on looking into it then. Their were no serving or any rough idle or any noise ran great. Just wouldn't start. And I love my 7.3 250k and ifs never been apart only starters ect. I was hoping to get the same use from the 6.0. Well see
Old Apr 6, 2011 | 10:06 PM
tonybon's Avatar
tonybon
Mandatory overtime... try the sensor tomarrow.
Old Apr 11, 2011 | 05:19 PM
tonybon's Avatar
tonybon
Ok I looked for the icp to unplug it. Can it be done from the top? Not sure where it is is their a video somewhere that shows a how to? Man I like my 7.3l it is a lot easier to work on (for me that is) :-)
