Ball joints
Old Apr 3, 2011 | 03:18 PM
Jr.Ranger-04's Avatar
Jr.Ranger-04
At 37-40K for a half ton truck not me I expect more in the line of quality
Old Apr 3, 2011 | 04:45 PM
LxMan1's Avatar
LxMan1
Originally Posted by Jr.Ranger-04
I have a little trick I use on my 04, u may have seen them it is a large hypo dermic needle with a jerk on the other end that will fitin a grease gun just insert in the rubber boots of ball joints and tie rod ends pump full of grease and remove makes such a small hole no grease comes out and not water goes in so we will see how it works I am at on 70K, not sure what the 2011's, but to me it looks like ford has cheapened them up all the way around, the engine compartment on the 5.0 just plain looks cheap to me...♦
I've done this forever on my 88 5.0 Mustang and it still has the original ball joints at 167K miles. I use a basketball inflator in the end of my grease gun. I had one that started squeaking about 15 years ago, did this and no noise and they are still tight as ever.
Old Apr 3, 2011 | 08:57 PM
Jr.Ranger-04
Very good then maybe I can keep my 04 going for quite awhile, I am not very impressed with the 11's I can see lots of issues down the road with them.....
Old Apr 7, 2011 | 02:19 PM
bigunit54's Avatar
bigunit54
Wear do you find this needle Jr Ranger. I would like to try this on my truck as well. Thanks.
Old Apr 8, 2011 | 04:11 PM
berry1234's Avatar
berry1234
How do you test for bad ball joints?
Old Apr 9, 2011 | 08:04 PM
bigunit54's Avatar
bigunit54
You are supposed to jack it up, put your hands at 12 and six on the wheel and try to see if you can move it. If you got play, your ball joints are probably bad. If you have a shop you trust they can check too. I have one that did my alignment, I told the guy to check the ball joints and he knew I was prepared to put them in if he said to, he told me they were fine, even told me how many thousandths of an inch of play they had in them, and that it was way below the amount you are allowed before replacing them. BTW, I found that grease injection needle at autozone, found it on line too, but got it at the zone. I am gonna try it soon.
Old Apr 13, 2011 | 10:27 AM
Jr.Ranger-04
Most auto parts stores have them u may have to look around a bit??
Old Apr 13, 2011 | 12:07 PM
berry1234's Avatar
berry1234
Are you moving the tire up and down or left to right or in and out? Or is any play bad?
70T351W
Aug 30, 2008 02:05 PM
kengarchow
Mar 31, 2008 06:02 PM
tim nick
1997 - 2003 F150
Dec 23, 2006 01:26 PM
WVF150VIANC
1997 - 2003 F150
26
Feb 25, 2005 09:22 AM
fowlerford56
Sep 9, 2004 09:00 AM
