First Mods On RT.
Old Apr 1, 2011 | 09:47 AM
Oslo's Avatar
Oslo
Talking First Mods On RT.
Truck sits stock right now. Can anyone estimate total horsepower increase with my new mods,they will be hear next week. First Tymar intake, 3to4 SS Tymar Hpermax DP to a 4in. SS exhaust cat delete full flow muffler and a EBPV delete. Thanks
Old Apr 1, 2011 | 09:50 AM
Talyn's Avatar
Talyn
With intake and turbo back exhaust, I think you gain about 15 horse power.
Old Apr 1, 2011 | 06:21 PM
Oslo's Avatar
Oslo
Sorry I had EVPV when I ment EBPV Opps does this change anything ?
Old Apr 1, 2011 | 06:47 PM
Talyn's Avatar
Talyn
not really.
Its not really a performance mod, just a safetey or EGT mod
It can decrease EGT's 50-100 degree if you remove the butterfly.
I'm guessing you got EBPV delete pedestal to swap in?
Thats the way to go.
Clay has them for sale if you want to go that route.
Dont forget to get o-rings.
Old Apr 1, 2011 | 06:52 PM
Oslo's Avatar
Oslo
I was going to tap the bottom hole 1/2 NPT and stick a brass fitting in it to cap it off if thats what you mean ?
Old Apr 1, 2011 | 06:58 PM
F350-6's Avatar
F350-6
He means when you pull the turbo pedestal to tap out the hole, make sure to use new o-rings when you re-install it. And don't forget to leave the EBP sensor at the base of the pedestal unplugged after you delete the EBPV.
Old Apr 1, 2011 | 07:00 PM
Talyn's Avatar
Talyn
Yeah, tapping it is fine.
I'm not sure if your supposed to pull the guts or not.
I think the return flow is only return flow, but I dont wanna tell you to pull the guts and then you have flow issues.
If i remember when doing mine, the EBPV is controlled all by incoming flow.
It really is a stupid setup, it should be electrical so it doesn't mess with turbo oil flow.
Old Apr 1, 2011 | 07:02 PM
Oslo's Avatar
Oslo
Yeah did not plan on new o rings Thanks for the heads up will order them anything else ?
Old Apr 1, 2011 | 07:08 PM
Oslo's Avatar
Oslo
I wish I was better with setting up links for you guys to view because I have instructions
from Dale at Tymar yoal could check um out .
Old Apr 1, 2011 | 07:19 PM
F350-6's Avatar
F350-6
Yes, yank out the guts. You'll need to for the plug to fit in the hole anyway. Otherwise the shaft will be in your way. I haven't seen Dale's instructions, but I've done it before. Just a snap ring on the back to remove, tap the shaft with a hammer and it will pop the back plate off and the guts will come out. Tap, clean, reinstall back plate and snap ring and you're good.
You are pulling the flapper valve out of the exhaust side of the turbo, right? Or at least wiring it open?
Old Apr 1, 2011 | 07:20 PM
Oslo's Avatar
Oslo
The O rings I just found were for the turbo pedestal if I remove the turbo, but I dont think I have to do that ?
Old Apr 1, 2011 | 07:26 PM
Oslo's Avatar
Oslo
Yeah Chris Im going to disconnect the 2 leads and grind the rivets off to pull out the flapper I would imagine the bottom hole I m plugging was for the staft and the top hole needs no attention ?
Old Apr 1, 2011 | 07:28 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
This is what you will need for o-rings.
Riffraff Diesel: Turbo / Pedestal O-rings
Old Apr 1, 2011 | 07:34 PM
Talyn's Avatar
Talyn
The best way to do this mod is to pull the turbo and pedestal.
With having it off, you would just save yourself a lot of headache by putting on the modded pedestal. Thats my .02.
but if you dont wanna pony up the dough.
You just need 1 set of o-rings, and just dont un-bolt the turbo from the pedestal and you wont have to replace those o-rings.
You'll see why a modded pedestal is good when you go to take it out. =)
If you dont have to take the pedestal out to get the EBPV guts out, that would be nice to know. I guess its possible.
Old Apr 1, 2011 | 07:40 PM
F350-6's Avatar
F350-6
You've lost me with the top and bottom hole. You're going to tap and plug the hole where the rod comes out on the pedestal, then you're going to remove the flapper from the turbo exhaust housing. If it's the exhaust housing holes you're referring to, if you pull the shaft the flapper used to sit on, you'll need to plug both the hole on top and bottom so you don't end up with a boost leak.
