Sponsored by: Real Truck
Lug Nut Length
Old Apr 1, 2011 | 01:04 AM
barthel's Avatar
barthel
Lug Nut Length
Hey All,
Does anyone have any idea how long the lug nuts are on 2000 F250 SD?
I know they're M14 X 1.5 RH but I'm not sure how long they are. The PO of my truck installed lock lugs for ALL lug nuts and I want/need to change them out.
Thanks.
Old Apr 5, 2011 | 10:03 PM
Acer's Avatar
Acer
We generally suggest using open end lug nuts whenever possible, alleviating any possibility of bottoming out without proper torque.
Thanks,
Acer Engineering
Old Apr 6, 2011 | 03:45 AM
brian42's Avatar
brian42
Veteran: Navy
I recently got new wheels and tires (and new lugs since the wheels are now lug-centric). They are long acorns (closed-ended) and I think are 2" long. I've been trying to find locking lug nuts but every one that's closed has been too short. If you don't go open-ended like Acer said, I'd go at least 2" long so that the stud doesn't bottom out at the end of the lug and leave you with a loose wheel.
Old Apr 6, 2011 | 10:03 AM
barthel's Avatar
barthel
Thanks for the info Brian, I was looking at ones that were 1.4 inches. The ones that are on there now are about an inch and a half. My next option would be 1.9 inches so that sort of clears that question up.
I will have a ton of lock nuts once I do this swap, if you're interested.
Old Apr 6, 2011 | 05:47 PM
bayou barataria's Avatar
bayou barataria
I got a nice set of locking lugs that looked like splines with a closed end since they were exposed for like $60.00 from tire kingdom, they looked pretty cool.
Old Apr 6, 2011 | 06:17 PM
barthel's Avatar
barthel
That's what I have now, I just am not a fan of locking lugs. I am looking for plain, chrome, closed end lugs, I just have to decide if 1.4 inches is going to be long enough (the ones on there now are 1.5)
Old Apr 8, 2011 | 06:03 PM
bayou barataria
The ones I got were not typical looking lock lugs they looked king of like the splines on a transmission shaft where the yoke slips on, (but you still needed a key to get them off) they looked o.k. with the stainless center caps.
Old Apr 8, 2011 | 07:14 PM
TennesseeMustangPerf's Avatar
Just a note, but they differ from SRW to DRW.
