Sponsored by: Real Truck
Iridium Spark Plugs?
Old Mar 31, 2011 | 02:49 PM
jd1083's Avatar
jd1083
I'm going to change the plugs out on my '01 F250 5.4L and I was originally going to go with the stock Motorcraft plugs, but a local auto parts store is closing down and has a very good deal on a set of Autolite Xtreme Iridium plugs and I was going to get a few opinions on these before I made my decision. Has anyone used Iridium plugs on their 5.4L? Pros/Cons to the Iridium plugs.
I know they are supposed to be better and or last longer than your avg Platinum plug but I also know that different engines respond to different plugs. Any opinions or experiences would be appreciated.
Old Mar 31, 2011 | 02:59 PM
F250CCowner's Avatar
F250CCowner
stick with the motorcraft.
Old Mar 31, 2011 | 03:12 PM
bpounds's Avatar
bpounds
How long did the originals last? Do the new ones really need to do better?
Not a 5.4, but I just had them replaced in my '02 Escape at 107k miles, and they looked like new. Probably a waste of money. I certainly would not spend more money looking for longer life.
Old Mar 31, 2011 | 05:29 PM
ro11ovr's Avatar
ro11ovr
Go with motorcraft. I ran some NGK iridium in my atv and they lasted less than 1 ride and were fouled out. The standard NGK with last for years in the same bike.
Old Mar 31, 2011 | 06:18 PM
creich68's Avatar
creich68
It seems that i've had the opposite luck as everyone else so far. I installed NGK iridiums in another vehicle (not SD) and loved them. Much better than the bosch that were previously in the vehicle. Athough fuel mileage didn't change (i didn't expect it to) but the idle did seem to be noticeably smoother. IMO, NGK makes some of the best plugs on the market. I've used them in vehicles, watercraft, mowers, and dirtbikes with great success. The only time I had one foul was in my dirtbike years ago, which I wasn't surprised. It's two stroke and I was just lugging around, which is what a race bike does not appreciate. I'd say if they are similar price, give a shot. I was glad I did it. Make sure you get the right gap for that particular plug. Just because a variety of brands of plugs will be available for your truck doesn't mean they will all have the exact same gap. For example, I just replaced the plugs in my 68 mustang. The autolites that were in the car specified 0.036, but the standard NGK's i put in required 0.034
Old Mar 31, 2011 | 09:00 PM
jd1083's Avatar
jd1083
Thanks for all the responses. As far as when the plugs were last changed I'm not sure because I just bought the truck about a month ago. The truck has 212K miles on it and it has the Motorcraft plugs in it. The plugs don't look too bad but you can tell that they've been in the truck for a while so I'm going to go ahead and change them out.
I can get the full set of Autolite Iridium plugs for a little bit less than the Motorcraft plugs so I was considering putting them in and seeing how they did. I can get a set of Autolite Platinum plugs for even less (about the price of 4 Motorcraft) but since this is my first Ford I didn't know how the Autolites performed in these motors. Anyone used Autolites in their 5.4 or 6.8L before?
Old Mar 31, 2011 | 09:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
Stay with the Motorcraft. These 5.4L and 6.8L engines are real sensitive to spark plug design. The Motorcraft just seem to work the best.
Old Mar 31, 2011 | 09:45 PM
Tstorms's Avatar
Tstorms
Autolite plugs will work fine. I have installed autolite double platnum plugs in many ford trucks and have never had a problem. I would expect the iridium plugs to work just as well. I have used the Autolite Iridium plugs in other vehicles with no problems. Autolite plugs are good plugs.
I'm a master certified Auto. technician with over 20 years Exp..
Old Apr 2, 2011 | 12:00 AM
jd1083's Avatar
jd1083
Thanks, I think I'll give the Autolites a try. Turns out the auto parts store practically gave them to me so if they don't work out I then I can take them out and go with the Motorcrafts, and since I got them so cheap I wouldn't have blown much money on them if they suck. Thanks for all the responses and opinions.
Old Apr 2, 2011 | 08:23 AM
FireMe's Avatar
FireMe
Autolite makes Motorcraft plugs, so it is no surprise they work very well on most Ford vehicles.
After being an electronic engine controls tech for 19 years, I can tell you that Autolite, Motorcraft, and AC Delco are the plugs you want to stick with. I can't tell you how many brand new Bosch and Champion plugs I replaced because of rough idles. They are a favorite of the tuneup shops around here and the vehicle owners are usually upset when they find out their brand new plugs are the problem. Engineering wise I can't tell you what the issue is, but I've experienced it many dozens of times.
krewat
Modular V10 (6.8l)
35
Jul 8, 2020 09:29 AM
Redfridge
Oct 10, 2016 03:19 PM
rvpuller
Modular V8 (4.6L, 5.4L)
May 15, 2016 04:10 PM
ssjrsw
Jul 23, 2008 10:46 AM
5.4L to Freedom
Feb 20, 2008 10:59 PM
