Radiator Install Screw up
Old Mar 18, 2003 | 01:10 AM
randallc's Avatar
randallc
Just a note to everyone out there... I was trying to track down a coolant leak for the last two weeks and came to the conclusion that it was the RAD. I even took the truck to the Ford dealership and one of the service guys took a look at it for me and also came to the conclusion that the RAD was shot. SO I purchased a new RAD and pulled the old one out, I started to inspect it and noticed that there is a drain hole at the bottom of one of the sides, well the drain was a bit loose and figured that it might have just been a loose drain plug. But I decided to replace the RAD just in case.
So just a note to anyone who may have a problem like I had. CHECK YOUR DRAIN VALVE!
I probably waisted a bunch of $$$. A mistake that I have noted for the future.
