Checking intake for leaks
Old Mar 30, 2011 | 10:22 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
I made up one of the leak detectors for the intake and didn't get much out of it when I had the regulator set at 20 psi. I then cranked a little more in there and finally got some air to come out of the passenger side of the intercooler boot. How much air do u have to put in there to get a good test out of it with out blowing something apart?
Old Mar 30, 2011 | 10:31 PM
BigAlsPSD's Avatar
BigAlsPSD
I wouldn't go over 35psi, with some tuning a stock turbo will see 30psi so that would be sufficient, I dont think you should "blow" anything apart below 50psi. Just my opinion though.
Old Mar 30, 2011 | 10:40 PM
Stroker 94 1/2
How can I find out how much I'm putting in. Checked it with a tire gauge and it wouldn't show anything on the gauge. Would my boost gauge show howmuch is in there?
Old Mar 30, 2011 | 11:37 PM
BigAlsPSD's Avatar
BigAlsPSD
I use regulator on air source, Boost gauge if mechanical should show the psi, if there are no leaks.
Old Mar 31, 2011 | 09:37 PM
Stroker 94 1/2
Big Al thanks for the help. Ya my gauge worked just like you said. Got the leak fixed and it blew the detector off while I was filling it and it scared the hell out of me. All is good. Is it supposed to leak air out of the ccv? I had to plug it with my finger and it was really starting to hold the pressure.
Old Apr 1, 2011 | 12:04 AM
BigAlsPSD's Avatar
BigAlsPSD
you need to connect your detector to the turbo side of the CCV, so that it is out of the picture or plug it would work too I suppose.
