Pulling turbo for rebuild...other mods to do while its off?
Getting parts ordered to replace my leaking up pipes at back of turbo. Figure that while the turbo is off I will rebuild it. Truck is stock and my daily driver so not looking to go to extremes but wonder what else I should do while turbo is off. Also is changing to a WW in turbo since its apart worth it in my case? Soon to be upgrading intake filter and going to full 4" exhaust. Any suggestions would be mighty appreciated! Thanks in advance
'01 F250 2wd stock other than Edge Programer
depending on the temperature where you live, in the winter. If not freezing, and you dont plan on using the EBPV as a jake brake, you can gut it, from the pedestal. Also, install new o-rings on the pedestal, where the turbo sits. Foil delete, off "charge" i.c. pipe, rebuild the fuel bowl, HPx and FRx from Clay (riffraffdiesel.com), 50 cent mod.....list can go on, bud.
He is in Texas so he will have warm weather to work.I agree with the EBPV and the .50 cent mod,and new o-rings.Torque your injector hold down bolts.
https://www.ford-trucks.com/forums/8...uld-share.html
Look at post #10.....https://www.ford-trucks.com/forums/9...rpms-long.html
By chance would you have a picture of what youre talking about? Ive got 287,000 mi on my baby and id hate for that to spring a leak. Hasnt happened yet so id like to take a look at it.
Trying not to spend a small fortune as we are going on vacation end of April but since I will be pulling a travel trailer I need to fix the important stuff before then
